Conquering the Monstrous Partial Fraction: Solving Complex Equations
  • Thread starter Thread starter WolfOfTheSteps
    Fraction Partial
WolfOfTheSteps
I know how to use the method of partial fractions in most circumstances, but I'm working on a problem that has gotten the best of me. How do I get from the left side of the following identity to the right side?
<br /> \frac{-2-2\omega^2}{-\omega^2+\sqrt{2}i\omega+1}<br /> \ = \<br /> \ 2 \ + \<br /> \frac{-\sqrt{2}-2\sqrt{2}i}{i\omega - <br /> \frac{-\sqrt{2}+i\sqrt{2}}{2}} \ + \<br /> \frac{-\sqrt{2}-2\sqrt{2}i}{i\omega - <br /> \frac{-\sqrt{2}-i\sqrt{2}}{2}}<br />​
I was able to factor the denominator and write the following equation:
<br /> A\left(\frac{\sqrt{2}+i\sqrt{2}}{2} +i\omega\right) \ + \<br /> B\left(\frac{\sqrt{2}-i\sqrt{2}}{2} +i\omega\right) \ = \<br /> -2-2\omega^2<br />​
but couldn't get much further because A and B don't have \omega^2 multiples to match up with the -2\omega^2 on the right side of the equation.
How do I handle this monster?
Note: i is the imaginary unit.
Thanks!
I would like you to show how you arrived at what you give since that is not what I get.
The first thing I did was multiply both numerator and denominator by -1 to get
\frac{2+2\omega^2}{\omega^2-\sqrt{2}i\omega-1}
Then the denominator factors as
\omega^2- \sqrt{2}i\omega- 1= (\omega-\frac{\sqrt{2}}{2}-i\frac{\sqrt{2}}{2})(\omega+\frac{\sqrt{2}}{2}-i\frac{\sqrt{2}}{2})
Putting those factors into the denominators and multiplying through by them gives
A(\omega+\frac{\sqrt{2}}{2}-i\frac{\sqrt{2}}{2})+ B(\omega-\frac{\sqrt{2}}{2}-i\frac{\sqrt{2}}{2})= 2+ 2\omega^2
Now set
\omega= \frac{\sqrt{2}}{2}+ i\frac{\sqrt{2}}{2}
and
\omega= \frac{\sqrt{2}}{2}- i\frac{\sqrt{2}}{2}
and it should be easy.
Thanks for your help!
Your denominator factors are not in the form I need them to be. I didn't check it, but I assume your work is correct. The problem is I need the denominator factors to be in the (a +i\omega) (where a is complex or real) form to take advantage of a known Fourier transform.
Here is how I arrived at my equation:
Let
(A+i\omega)(B+i\omega) = 1 + \sqrt{2}i\omega-\omega^2
Then we want A and B to satisfy the following conditions:
A+B = \sqrt{2}
AB = 1
Solving that system we get:
A= \frac{\sqrt{2}}{2}(1-i)
B= \frac{\sqrt{2}}{2}(1+i)
Hence,
1+\sqrt{2}i\omega - \omega^2 = \left(\frac{\sqrt{2}}{2}(1-i)+i\omega\right)<br /> \left(\frac{\sqrt{2}}{2}(1+i)+i\omega\right)
And from that I was able to get the equation I gave before:
And that's where I was stuck.
HallsofIvy,
I got it now. I found out that I have to first do long division to get the numerator to be 1 degree less than the denominator, and then use the method of partial fractions.
Dang, didn't even occur to me!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
