Partial Fraction Integration Help =(
The discussion revolves around the integration of the function \( \frac{1}{x^3+x} \) using partial fraction decomposition. Participants are exploring the correct setup for the integration and the determination of constants involved in the decomposition.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Some participants attempt to decompose the integrand into partial fractions but encounter difficulties in determining the constants B and C. There is confusion regarding the correct form of the integrand, with variations noted between \( \frac{1}{x^3+x} \) and \( \frac{1}{x^3-x} \). Others suggest different methods for finding the constants, including substituting specific values for x and comparing coefficients.
The discussion is active, with participants providing various approaches to the problem. There is no explicit consensus on the correct method or values for B and C, but multiple lines of reasoning are being explored, indicating a productive exchange of ideas.
Participants are working under the constraints of homework rules, which may limit the extent of guidance provided. The original poster's confusion about the integrand's form has led to differing approaches in the discussion.
hellos
can anyone help me with this integration
integral (dx)/(x^3+x)
i tried solving it with partial integration and got stuck when i got find B and C...this was what i did
= integral (dx)/[x(x^2 + 1)]
= 1/[x(x^2 - 1)] = A/x + (Bx+C)/(x^2 + 1)
=> 1 = A(x^2 + 1) + (Bx+C)(x)
=> 1 = Ax^2 +A + Bx^2 + Cx
A = 1
then i got stuck here on how to get the B and C variable
Thanks in advance to those who can help
The question says [tex]\int\frac{dx}{x^3+x}[/tex] while your answer contains [tex]\int\frac{dx}{x(x^2-1)}[/tex]. Which is right?
= integral (dx)/[x(x^2 - 1)]
= 1/[x(x^2 - 1)] = A/x + (Bx+C)/(x^2 - 1)
=> 1 = A(x^2 - 1) + (Bx+C)(x)
=> 1 = Ax^2 - A + Bx^2 + Cx
A = -1
?Is your integrand [tex]\frac{1}{x^3+ x}[/tex] or [tex]\frac{1}{x^3- x}[/tex]? You give both.
If it is [tex]\frac{1}{x^3-x}[/tex] then you need to factor more:
x3- x= x(x2-1)= x(x-1)(x+1) so
[tex]\frac{1}{x^3- x}= \frac{A}{x}+ \frac{B}{x-1}+ \frac{C}{x+1}[/tex]
Then 1= A(x-1)(x+1)+ B(x)(x+1)+ C(x)(x-1) and you can determine A, B, C by letting x= -1, 0, 1 in turn.
If it is [itex]\frac{1}{x^3+ x}[/itex] then it is a little harder:
x3+ x= x(x2+ 1) and x2+ 1 cannot be factored further (in terms of real numbers).
[tex]\frac{1}{x^3+x}= \frac{A}{x}+ \frac{Bx+C}{x^2+ 1}[/tex]
then 1= A(x2+1)+ (Bx+ C)x.
Taking x= 0, A= 1. Now there are 3 different ways to determine B and C.
a) Subtract 1/x from the fraction:
[tex]\frac{1}{x^3+x}- \frac{1}{x}= \frac{1}{x^3+x}- \frac{x^2+1}{x^3+x}= -\frac{x}{x^2+1}[/tex]
so that the Bx+ C in [itex]\frac{Bx+C}{x^2+1}[/itex] is clearly B= -1, C= 0.
b) Compare like powers of x:
with 1= A(x2+1)+ (Bx+ C)x and A= 1, we have 1= x2+ 1+ (Bx+ C)x= (B+1)x^2+ Cx+ 1. We must have B+1= x and C= 0 giving, again, B= -1, C= 0.
c) Use some values of x other than 0:
1= 1(x2+1)+ (Bx+ C)x.
Taking x= 1, 1= 2+ B+C and taking x= -1, 1= 2+(-B+C)(-1)= 2+B-C
Now solve the two equation B+ C= -1 and B-C= -1 to get, once again,
B= -1, C= 0.
Thanks for the input guys
  • · Replies 18 ·
