Particle in a box with moving sides
  • Thread starter Thread starter Felicity
    Box Particle
Felicity
a particle is in the ground state of a box with sides x = + or - a. Very suddenly the sides of the box are moved to x = + or - b (b>a). What is the probability the particle will be found in the ground state for the new potential? What is the probability that the particle will be found in the first excited state? In the latter case, the simple answer has a simple explanation. What is it?
2. Homework Equations and the attempt at a solution
I believe the probability can be calculated by An2 where
An = ∫dxψ(x)(2/a)1/2cos(πx/a) for the ground state
An = ∫dxψ(x)(2/a)1/2sin(2πx/a) for the first excited state
Is this correct?
Would the interval be the original or the new walls?
How can I solve this without knowing ψ(x)?
Thank you
I can't really understand some specific aspects of your problem (e.g. bounds), but I understand the general problem statement.
You are given the initial wave function: the particle is in the ground state within some boundary. Next, the boundary is moved to some new one. Consider this transition to be instantaneous. Now, draw the new potential and its boundaries along with the original ground state wave function; notice that the original wave function does not span the whole range of the new boundary.
Hint: Since your boundary has changed, so did the general solution to infinite square well potential.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
