Particle in a uniform electric field
A particle is subjected to a uniform electric field of 450 N/C in the -y direction, with a mass of 4 g and a charge of -19 µC, initially moving at 40 m/s at a 25° angle. The force acting on the particle is calculated to be 0.00855 N. The acceleration was initially miscalculated, with the correct value being 2.1375 m/s² due to the negative charge experiencing an upward force. The y-coordinate of the particle's position at t = 5.7 s is determined to be approximately 131.08 m after correcting for the direction of the force. Accurate calculations and understanding of the force direction are crucial for solving such problems.
Bryon
Throughout space there is a uniform electric field in the -y direction of strength E = 450 N/C. There is no gravity. At t = 0, a particle with mass m = 4 g and charge q = -19 µC is at the origin moving with a velocity v0 = 40 m/s at an angle θ = 25° above the x-axis.
(a) What is the magnitude of the force acting on this particle?
F = 0.00855N
(b) At t = 5.7 s, what are the x- and y-coordinates of the position of the particle?
x = 206.6381754m
y = ?
y = y0 + vy0*t + 0.5*ay*t2
vx = v*cos(25)
vy = v*sin(25)
a = m/F
a = 0.004/0.00855 = 0.467836257
vy = 40*sin(25) = 16.90473047
y = 16.90473047*5.7 + 0.5*(-0.467836257)*5.7^2 = 88.75696368
Im not sure where I messed up here. Any thoughts?
Thanks!
hi
your calculation for 'a' is wrong
a=\frac{F}{m} = \frac{0.00855}{0.004} = 2.1375 m/s^2
now electric field is downwards , and charge is negative so the electric force on the charge will be in +y direction, so your acceleration should be positive.
I am getting y = 131.08 \, \, m :smile:
Make sure of the direction of the force on the particle.
Ah thanks...I didnt realize I flipped mass and force for acceleration, and I should have realized the correct direction. Ill punch in the numbers and see what I get. Thanks!
