Particle experiencing only an angular force, determine the r dot
  • Thread starter Thread starter flinnbella
    Particle
The discussion revolves around determining the relationship between the radial velocity (r') and the radial position (r) for a particle experiencing only angular force. The participants analyze the equations of motion in polar coordinates, noting that the radial force is zero, leading to the equation r'' = rθ'^2. A key insight is recognizing the dependence of r' on r, which is essential for solving the problem. The conversation highlights the importance of using the chain rule to derive relationships between different derivatives. Ultimately, the original poster successfully resolves their confusion with the help of insights shared by others.
flinnbella
Consider a particle that feels an angular force only, of the form Fθ = m r' θ'.
Determine the dependence of r' on r.
Relevant equations are:
particle acceleration in polar coordinates
Fr = 0
F(theta) = mr'θ'.
Hey, I've been working on this for a couple hours, and still no luck.
Since the force in the radial direction is zero, I set
r'' = rθ'^2.
Then since Fθ = m r' θ' and, since it's in polar coordinates, Fθ = m(2r'θ' + rθ'').
Setting these two equal, I get: -r'θ' = rθ''
At this point, I'm stumped. I try to substitute the angular velocity/ acceleration for something in terms of r, try to integrate, but inevitably I reach a point where I can't integrate anymore.
flinnbella said:
Homework Statement: Consider a particle that feels an angular force only, of the form Fθ = m r' θ'.
Relevant Equations: Relevant equations are:
Fr = 0
F(theta) = mr'θ'.
r'' = rθ'^2.
You can rewrite that as$$r\ddot \theta + \dot r \dot \theta = 0$$Do you recognise an exact time derivative there?
PS you also have another equation of motion from the ##\hat r## component.
PPS is the question to get the dependence of ##\ddot r## on ##r##? I.e. a differential equation for ##r##.
As far as I can tell it's either what you suggest ( which is very clean ), or you get ##\dot r ## as a function of ##r, \ddot r , \dddot r##.
What can be considered "an angular force" in this type of problems?
A force that has an angular but no radial component?
So ##\vec F=m\dot r\dot\theta\hat\theta##, right @flinnbella ?
Yes exactly. There is no radial force and the radial acceleration is zero
No its on the dependence of the radial velocity on the radial position.
It's on r dot dependence on r, not r double dot
It's difficult to know what is required, but if we take ##\frac d {dt} \dot r = \ddot r##, then that gives us a relationship between ##\dot r## and ##r##.
You should be able to make progress in any case, following the conventional approach in these problems (as I hinted at in the posts above).
You may recall ##\ddot x=\dot x\frac{d\dot x}{dx}##.
Likes erobz and PeroK
Behold the power of the Chain Rule!
Wow, I figured it out, thank you
Thanks! but I’ll forward that to the providers of the key insights @PeroK , @haruspex
