Particle Takes Infinite Time to Reach Top of Potential Hill
Proofrific
A particle is moving in a potential
V(R) = \frac{1}{2} \left( \frac{1}{R} - \frac{1}{R^2} \right)^2.
If you plot this, is has a well at R = 1 with height V(1) = 0 and a hump at R = 2 with height V(2) = 1/32. Question: If a particle has energy 1/32, show that it takes log infinite time to escape from the potential barrier.
See above
Using either F=-grad(V) or the Euler-Lagrange equation, I get
m\ddot{R} = \frac{-1}{R^3} + \frac{3}{R^4} - \frac{2}{R^5}.
How do I solve this differential equation?
Ultimately, I want to find an equation for the velocity of the particle so that I can integrate it to find the time to escape. That is, assuming that we're at R = 1 at t = 0, I want to find the time to reach R = 2 by solving:
2 = \int_0^t \dot{R}(t) dt
Hi Proofrific! :smile:
Standard trick :wink:
either multiply both sides by R' (so eg the LHS is m(R'2)'/2)
or write R' = V, then R'' = dV/dt = dV/dR dR/dt = v dV/dR :smile:
(same result either way)
(and btw, this is where 1/2 mv2 comes from in KE)
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
