Particles moving in a straight line
A car accelerates uniformly from a speed of 6 m/s at point A to 14 m/s at point B. The distance from A to B is calculated using the average speed formula, resulting in s = 5t. The midpoint C requires finding the speed at that point using the equations of motion. The initial calculations for acceleration and final speed at C are questioned, suggesting a need for reevaluation. The discussion emphasizes the importance of double-checking calculations to arrive at the correct answer.
phospho
A car moving with uniform acceleration along a straight level road, passed points A and B when moving with speed 6m s−1 and 14m s−1 respectively. Find the speed of the car at the instant that it passed C, the mid-point of AB.
My working:
acceleration from AB: v = u + at, 14-6 = at, 8/t = a
distance from AB is:
s=((u+v)/2)t
s =(6+14/2)t
s = 5t
as C is the midpoint of AB, s/2 = (5/2)t = AC
so using u = 6, s = (5/2)t, a = 8/t, v = ?
v^2 = u^2 + 2as
v^2 = 36 + 2((8/t))((5/2)t)
v^2 = 36 + 40
v^2 = 76, v = 2root19, which is wrong
any ideas?
phospho said:
s=((u+v)/2)t
s =(6+14/2)t
s = 5t
Hi, phospho. Recheck the calculation for the steps shown above.
eek, thanks.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
