Partition Coefficients: What Do They Tell Us?
The partition coefficient indicates the solubility of a compound in two different solvents, reflecting its distribution between them. A low partition coefficient suggests that the compound is less soluble in the solvent of interest, but this must be interpreted in the context of the specific solvents used. In the case of benzoic acid, despite a calculated partition coefficient of around 0.25, which implies greater solubility in water, the literature states that benzoic acid is actually more soluble in methylene chloride. The discussion highlights the importance of considering both the amounts of solute in each phase and the volumes of the solvents when interpreting partition coefficients. Understanding intensive versus extensive properties is crucial for accurate analysis in such experiments.
ahhppull
What exactly does partition coefficient tell us? if I have a low partition coefficient, does that mean its less soluble in that compound?
I had .0555g Benzoic acid mixed with water and methylene chloride. It formed two layers of which BA (Benzoic acid) is dissolved in water or methylene chloride. I pippeted out the methylene chloride and heated it, and there is .011g of BA in the vial. I got a partition coefficient of around .25. Does this mean that BA is more soluable in water since .0445g of BA was still in water?
But this doesn't make sense because when I looked it up, it says BA is more soluble in methylene chloride.
I guess you are confusing intensive and extensive properties. You have not mentioned volumes - what they were?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
