Fermi Energy, Temp & Wave Vector Calc for Protons & ^3He
Winzer
Calculate fermi energy, fermi temp and fermi wave vector.
a)Protons with n= 1.0E43 m^{-3}
b) ^{3}He in liquid He (atomic volume= 46E^-3 m^3
E_f=\frac{h^2}{8 m} (\frac{3 n}{\pi V})^\frac{2}{3}
T_f= \frac{E_f}{k_B}
I get the energy and temp.
Is the wave vector equation:
k=\sqrt{\frac{8 \pi^2 m E_F}{h^2}}?
for the last one \frac{n}{v}=\frac{3}{ 46E^{-3}}?
You remember E=\frac{\hbar^2 k^2}{2m}. So just replace the energy and wavevector with the Fermi variables, so you are left with:
E_F=\frac{\hbar^2 k_F^2}{2m}
For part (b) check the units on the atomic volume. Is it per mole?
Not sure. It says ^{3}He atoms in liquid ^{3}He. So it should be n=3(3fermions) and V=46E-30 m^3. I think that sounds right.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
