Parts, componets, and things that do stuff
  • Thread starter Thread starter maxsthekat
    parts
The discussion focuses on sourcing parts for robotics, specifically bearings, shafts, gears, and chains. McMaster-Carr is highlighted as a top choice for its convenience and fast service, though users are advised to compare prices due to potential markups. Other recommended websites include Grainger, Digikey, Small Parts.com, Cole Parmer, Applied Industrial, and Motion Industries. Additionally, surplus stores and online searches for electronic surplus are suggested for more options. The conversation emphasizes the importance of finding reliable sources for various components in robotics projects.
maxsthekat
Parts, componets, and things that "do stuff"
Hi guys!
I'm actually an electrical engineering student, but I figured this might be more applicable here. I'm trying to find websites that are good for ordering parts such as bearings, shafts, gears, chains, cogs, and more. I'm planning on incorporating these items into simple robot designs; I've seen lots of "robot" sites with plenty of servo motors, but I'm having trouble finding anything really beyond this.
So, what sites do you like to order parts from? :)
thanks!
-Max
While McMaster-Carr is the most awesome-est company and website ever, you do have to be a bit careful in that they can add a good bit on to the price of some basic things. This is coming from someone who uses them on almost a daily basis, so I have a pretty good idea on this. Just do yourself a favor and shop around if you are watching your pennies. In a lot of cases, the convenience and extremely fast turnaround time is worth the extra bucks.
Other sites are:
Grainger
Digikey
Small Parts.com
Cole Parmer
Applied Industrial
Motion Industries
I'll try to think of more later. It's tough without my work bookmarks in front of me.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
