Path Difference: Why a Cold Spot Forms at S
A cold spot in microwaves occurs due to destructive interference, where waves arriving at point S are out of phase. The path difference is calculated by subtracting the distances traveled by the waves reflecting off different surfaces. In this case, the calculation involves determining the total distance traveled by each wave and then finding the difference. Dividing the path difference by the wavelength helps identify the number of wavelengths in that difference, which is crucial for understanding the interference pattern. Understanding these principles clarifies why cold spots form in microwave fields.
Luke1121
I was doing a past paper earlier and i got a question about cold spots in microwaves and i needed to calculate path difference the question was:
---------|------->S<---------|--------- Explain why a cold spot is formed at S
18cm | 6cm. 12cm | 30cm
The question showed the waves reflecting off the top and sides of the microwave which are shown by the -|-
It was 4 marks so a calculation should be done and i did (30+12)-(18+6) then i didnt know what to do, i then found out you are supposed to divide (30+12)-(18+6) by 12. But I am not really sure why, can anyone explain why? Thanks
What is the wavelength or frequency of the microwaves?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
