PDE:Cauchy Problem for Heat Equation
  • Thread starter Thread starter proximaankit
    Heat Heat equation
proximaankit
Solve the Cauchy problem
ut =kuxx, x ∈ R, t>0, u(x, 0) = φ(x),
for the following initial conditions.
(a) φ(x)=1if |x|<1 and φ(x)=0 if |x|>1.
Write the solutions in terms of the erf function.
u(x,t)=∫G(x-y,t)*φ(y)dy from -∞, to ∞
where G(x,t) is the heat kernel or fundamental solution to heat equation.
I am not sure if this correct:
Separate the integral into different parts according above condition and then plugin φ(x) value for φ(y) in the integral. And then proceed from there on
Sounds good to me. Just do it!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
