Pendulum Problem: Solve 100 Oscillations in 50cm Rod
  • Thread starter Thread starter Clearik
    Pendulum
The discussion centers on solving a pendulum problem involving a 50 cm rod with a point mass attached, focusing on calculating the period of oscillation and the total moment of inertia. The initial approach to finding the period used the given moment of inertia, but adjustments were needed due to the pivot point not being at the center of mass. Participants emphasized the importance of applying the parallel axis theorem correctly to determine the total moment of inertia, which should only include the rod and point mass. The method for calculating the time for 100 oscillations was confirmed as simply multiplying the period by 100. Overall, the conversation highlights the need for careful consideration of the pivot point and inertia calculations in pendulum dynamics.
Clearik
A pendulum is composed of a thin rod of length L = 50 cm, a moment of inertia of I = 0.2kgm2 with respect to its center and mass M = 400g. Attached to the bottom of the rod is a point mass (m = 200g). The pendulum swings in a vertical plane, attached by the top end to the ceiling.
T = 2∏√(I/Mg x d)
*I think*
T = 2∏√(.2/(.4)(10) x .25)
No radius was given for the point mass, so I assumed the moment of inertia of center of mass is .2kgm2 and therefore the distance of center of mass (d) would be L/2 or .25m
Did I go about solving this correctly?
Also, the second problem asks: How long will it take for the pendulum to perform 100 oscillations?
Would I simply multiple the period I found from the first part by 100?
Thank you all for your time and consideration.
Don't guess.
It helps to sketch the situation out:
- Which part of the rod is attached to the ceiling?
- Which part of the rod has the point mass attached to it?
You are given the moment of inertia for a rod pivoted at the center of mass - but that is not where the rod is pivoted - so you need to adjust this (hint: parallel axis theorem).
... yes.
The question is basically checking if you understand what "one period" means.
It's good to see you thinking beyond what's in the question - just remember that everything you want to assert has to be justified by something said inside the problem statement.
Likes 1 person
Hmm, I see.
The equation for moment of inertia at end of rod is Iend = mL2/3
Therefore, Iend = 1.33 kgm2
From my understanding of using the parallel axis theorem to calculate moment of inertia of a system, one would simply add up the inertias.
Isystem = Icom + Iend of rod + Ipoint mass
Isystem = .2kgm2 + 1.33kgm2 + 2.00kgm2
Isystem = 3.53kgm2
Does this sound more reasonable?
That's not how the parallel axis theorem works.
You should only have two terms to calculate inertia: ##I_{tot}=I_{rod}+I_{point}##
You can just look up the inertia for the rod-pivoted-about-one-end.
However, since the question tells you the com inertia, they are expecting you to use that and the parallel axis theorem. Either way is correct but both together is not.
Aside: interesting... the PF spell-checker does not accept either "inertias" or "inertiæ" (accepted plurals for "inertia").
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
