Pendulum speed given length and angle
A circular pendulum of length 1.2 m at a 25-degree angle to the vertical requires calculating the speed of the mass at the end of the string using energy conservation principles. The initial approach involved using the formula 1/2mv^2 = mgh, leading to a speed calculation of 1.448 m/s. However, discussions highlighted the importance of considering centripetal force and rotational dynamics, prompting a reevaluation of the problem. Ultimately, the correct approach involves using the radius of the circular path, resulting in a final speed of approximately 1.522 m/s. The conversation emphasizes the need to differentiate between circular and simple pendulum dynamics for accurate calculations.
Kirasagi
A circular pendulum of length 1.2 m goes around at an angle of 25 degrees to the vertical.
Predict the speed of the mass at the end of the string. Use g = 9.8 m/s2.
Answer in units of m/s
1/2mv^2 = mgh
h = L - Lcosθ
I used the above formula doing:
1/2mv^2 = mgh
v = √2g(L - Lcosθ)
Plug n' chug:
v = √2*9.8*(1.2 - 1.2cosθ)
v = 1.448 m/s
I've seen variations of this problem before, but I'm not really sure what I'm doing wrong.
1/2mv^2 = mgh
h = L - Lcosθ
1/2mv^2 = mgh
v = √2g(L - Lcosθ)
Plug n' chug:
v = 1.448 m/s
What's the difference between a "circular pendulum" and a regular "pendulum"? The difference will make all the difference :smile:
1/2mv^2 = mgh
How did you apply conservation of energy? :confused: There was an external force that made the pendulum start its circular revolutions from its initial state.
As I see the problem, the pendulum is revolving about the vertical axis. Drawing a diagram will help :smile:
To be honest I'm not really sure, I don't remember paying attention to pendulums too much. I'm assuming it also rotates/spins as it moves? Not sure what can I tie with that.
Am I doing this problem the right way? But having that idea, maybe I should add rotational kinetic energy?:
1/2mv^2 + 1/2IW^2 = mgh
W = v/r
Am I going on the right track?
Initially, another idea I had was to use centripetal force: mv^2/r, and using force diagrams.
Your initial idea was a good one. Follow it up!
The pendulum only revolves about the vertical axis.
Try this out :smile:
Edit : somehow gneill is way faster!
I see, this was the way I saw it at first but I thought it's more complicated.
So:
Fx = Tsinθ = mv^2/r
Fy = Tcosθ = mg
T = mg/cosθ; plugging that in for Fx..
mv^2/r = mgtanθ, so..
v = √rgtanθ, where r = Length ? Not sure if I derived everything correctly.
Assuming I did everything right, final answer came to be v = 2.3417 m/s.. though I tried that a long time ago but got it wrong.
Kirasagi said:
...where r = Length ? Not sure if I derived everything correctly.
r is the radius of the horizontal circle where the pendulum is revolving. So, what component of the length will give you that?
Would that be Lsinθ?
so
v = √g*Lsinθ*tanθ
v = 1.52234 m/s
so
v = √g*Lsinθ*tanθ
v = 1.52234 m/s
Yep!
Got it right on my last try. Thanks!
