Percent difference and uncertainty
The discussion focuses on calculating the percent difference and uncertainty between two values, specifically using the formula for percent difference. The user expresses difficulty in obtaining the correct uncertainty for their answer despite multiple attempts. It is suggested that when subtracting values, the uncertainties should be added, while for division, uncertainties should be converted into percentages and combined before applying them to the main value. The importance of showing attempts is emphasized to facilitate better guidance. Overall, the conversation centers on the correct application of uncertainty in calculations.
mike2601
How do we solve this problem?
% Difference = (l 0.282 +/- 0.0019 - 0.288 +/- 0.04 l) / 0.285 +/- 0.02
Percent Difference = (l value - average value l) / average value x 100%
many attempts made but cannot get correct uncertainty for the answer
Welcome to PF, Mike.
You are supposed to show your attempt(s) so we have some idea what method you are supposed to use, and to avoid giving solutions to people who haven't tried the problem on their own.
For the subtraction, I would add the uncertainties.
For the division, I would convert the uncertainties into per cents of the main values, add the per cents, and finally find that % of the main value.
