Why is there a 3° variation in angles when calculating the Ackerman percentage?
  • Thread starter Thread starter Reddy
    Angle
The discussion addresses the calculation of Ackerman angles for inner and outer wheels, revealing a discrepancy between calculated and expected angles. A 3° variation in angles results in a 71% Ackerman percentage, which is considered acceptable but still less than true Ackerman geometry. The user notes that reducing tie rod lengths improved the outer wheel angle but is not feasible due to geometric constraints. The complexity arises from the placement of the steering knuckle arm and tie rod end joint relative to the wheel's steering axis. The conversation emphasizes that achieving perfect Ackerman geometry can be challenging due to these design factors.
Reddy
Hiii...
I hav caluclated my inner wheel lock angle(38.25°) and outter wheel lock angle(26.16) from formulae ...and I tried to caluclate for X degree rotation of my inner wheel how much my outter wheel rotates...ex:- at 20° rotation of inner wheel...17.7° of outter wheel ...nd at 38.25 I got outter wheel angle as 29.35° ...but actually that should be 26.16°, ryt?
Why this happens ??
And i reduced my tie rods length by 0.1inch on each in my calculations...I got the required outter wheel angle 26.16°..
But I can't reduce my tie rods lengths according to geometry...
If reducing tie rods length is d solution, thn how to satisfy geometry too??
Because, reducing tie rod lengths is not the solution. Ackerman geometry is mainly a function of the steering knuckle arm placement, i.e., tie rod end joint placement relative to the steering axis of rotation for the wheel. Since these axes are not vertical, the geometry gets complicated. If you're getting only 3o deviation from true Ackerman geometry at full lock, you're doing well.
Tq ..
3° varaiation in angles giving me 71% Ackerman .i.e..,less than true Ackerman..I didn't fix it for less than true Ackerman ...it came automatically... I don't know what makes in design
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
