What Happens to Momentum in a Perfectly Elastic Wall Collision?
In a perfectly elastic collision with a massive wall, the momentum of a particle changes direction but not magnitude. The initial momentum is represented as m*v_x, and after the collision, it becomes -m*v_x. The change in momentum is calculated as Δp = m(v_x - (-v_x)), resulting in Δp = 2m*v_x. The magnitude of the change in momentum is therefore 2mv. This discussion clarifies that while momentum is conserved, the direction reversal leads to a significant change in momentum.
Dorney
[SOLVED] Perfectly Elastic Collision
1. A particle of mass m and speed V collides at a right angle with a very massive wall in a perfectly elastic collision. What is the magnitude of the change in momentum of the particle?
2. P before colision = P after collision.
3. I think the answer is zero. Is this correct?
Thanks in advance! :)
sorry, wrong
Well, it does change direction. :) So it's -1 x P (for the new velocity).
Momentum prior to collision: m\vec{v_1}
Momentum after collision: m\vec{v_2}
\vec{v_1}=v_x \hat{x}
\vec{v_2}=-v_x \hat{x}
\Delta{p}=m(\vec{v_1}-\vec{v_2})
\Delta{p}=m(v_x\hat{x}- - v_x\hat{x})
\Delta{p}=2m v_x \hat{x}
Since it asks for magnitude:
2mv
Sorry, bill is right, i was wrong.
Perfectly elastic collision occurs in isolated systems tho no? so you can't really consider this a collision, this is like magnitude of velocity in equals to magnitude of velocity out.
2mv
Thank you! That makes so much more sense!
