How Do You Calculate the Period of a Traveling Wave?
  • Thread starter Thread starter Noctix
    Period Wave
To calculate the period of a traveling wave, the displacement equation y(x,t) = y0 sin(2π(x/λ - t/T)) is used, where y0 is the amplitude, λ is the wavelength, and T is the period. The discussion emphasizes that the period remains constant regardless of time, suggesting setting t to 0 for simplification. By analyzing the sine function, it is noted that one complete cycle occurs over a distance equal to the wavelength. The participant expresses confusion about how to isolate the period from the equations provided. Ultimately, the goal is to determine that the period of the wave is 1.17 seconds.
Noctix
At x = 15.0 cm and t = 2.00 s, the displacement of a traveling wave is 8.66 cm. The amplitude of the wave is 10.0 cm, and its wavelength is 8.00 cm. Assume the smallest positive phase angle.
What is its period?
y(x,t)=y0sin2pi(x/lambda-t/period)
y(2)=10sin(8.66/8-2/T)
I don't know if I set it up right, and I don't knw how to solve the equation from here because i don't know the value of y... any and all help is greatly appreciated.
The period of the wave is the same no matter what t is so take t to be a fixed number, 0 is simplest. Then we have y(x)= y_0 sin(2\pi (x/\lambda).
We know that the period of "sin(x)" alone is 2\pi- so that one period of sin(2\pi(x/\lambda)) will occur between 2\pi(x/\lambda)= 0 and 2\pi(x/\lambda)= 2\pi.
sorry, i don't quite understand what you're saying. If we use t=0, the period is canceled out of the equation, isn't it? even if not, how do i get an answer out of your two final equations?
sorry for being slow... i haven't had trig, so this is all really new to me.
also, I should have mentioned this earlier, but I'm aiming for the answer period=1.17s
