Period of Motion: Find Mass 0.85kg Piston's Period of Motion
  • Thread starter Thread starter Coatesy
    Motion Period
The discussion focuses on calculating the period of motion for a piston with a mass of 0.85 kg, modeled as simple harmonic motion. Given the acceleration of 8 m/s² when the piston is 10 cm from the midpoint, the formula a = -(2πf)²x is applied to find the frequency. Participants suggest rearranging the equation to solve for frequency (f) and subsequently determining the period (T) using the relation T = 1/f. The calculated velocity of 1.26 m/s is mentioned, but its necessity for finding the period is questioned. Ultimately, the key objective is to derive the period of the piston's motion based on the provided parameters.
Coatesy
Poster has been reminded to post schoolwork in the Homework Help forums and show their work
The movement of a particular piston of mass 0.85kg may be modeled with a simple harmonic. Given that its acceleration is 8m/s when 10cm from the mid position. Find the period of the motion??
I found velocity to = 1.26m/s, but I am not even sure if i need to calculate the velocity.
a=-(2πf)2x
We have a (= 8 m/s)
We know 2π (constant)
And we know x (= 10cm)
Rearrange to find f.
Period = 1/f
Likes Coatesy
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
