Can Multiple Periods Determine a Fundamental Period in Functions?
A function can have multiple periods, but the fundamental period is defined as the smallest positive period. In the discussed function, f[n] = 1 if n is a multiple of 2 or 3, and 0 otherwise, both 2 and 3 were initially thought to be periods, but it was clarified that 2 is not a period. The least common multiple of 2 and 3 is 6, which is a period, but the function is not periodic with either 2 or 3. Constant functions can have any real number as a period, but they do not have a fundamental period since the set of periods is unbounded below.
Bipolarity
Can a function have two periods? If so, which is the fundamental period?
Consider the following function, $$ f : \mathbb{N} → \mathbb{R} $$, defined by
f[n] = 1 if n is a multiple of 2 or 3, and 0 otherwise.
Then it is clear that 2 and 3 are both periods of this function, since translation of the input by either 2 or 3 renders the function's value invariant.
6, being the least common multiple of 2 and 3, is also "a period" of this function. But which is the fundamental period?
Thanks to anyone who can clarify this confusion!
BiP
Mathematics news on Phys.org
Yes, and the smallest positive number is the fundamental.
Well
f(1) = 0
f(2) = 1
f(3) = 1
f(4) = 1
f(5) = 0
f(6) = 1
But ##1 = f(3) \neq f(3+2) = f(5) = 0## so 2 isn't a period.
Well
f(1) = 0
f(2) = 1
f(3) = 1
f(4) = 1
f(5) = 0
f(6) = 1
Ahh, I see, my mistake.
Are there functions for which 2 and 3 are both periods?
BiP
BiP
pwsnafu already answered this question by his example in post #2. f(2) = f(4) = f(6) = 1, and f(3) = f(6) = 1.
(Embarrassed mod note): Disregard what I wrote: 2 is NOT a period of this function.
pwsnafu answered in the negative. This f is not periodic with period 2. Nor is it periodic with period 3.
If any f() is periodic with both period x and with period y then it is clear that it is also periodic with every period that is a non-zero sum of integer multiples of x and y. In particular, it must be periodic with period (y-x).
3-2 = 1. It folllows that in order for f() to be periodic with period 3 and with period 2 that it must then also be periodic with period 1.
jbriggs, yes you are correct. I was lulled into thinking that since f(2) = f(4) = f(6) = 1, that 2 was a period. Not so. Thanks for the correction.
On this subject, you might notice that the constant function ##f(x)\equiv C## has period ##r## for any real number ##r##.
What would be considered the period of a constant function?
BiP
BiP
Pick any number a, let b be an arbitrary real number. Then, since C = f(a) = f(a + b) = C, the period is b. That's pretty much what LCKurtz was saying.
I see, but what would be the fundamental period? 0?
BiP
What is the definition of a fundamental period? If you apply that definition, would a constant function have a fundamental period?
No, because the set of periods is unbounded below?
BiP
You might find this short article in the American Mathematical Monthly interesting:
R. H. Cox and L. C. Kurtz. 1966. Real periodic functions. Am.Math.Mon.,73,761
Here's a link to the article:
http://www.jstor.org/stable/2313992
If you are logged into a university account, you should just be able to open it. It's only about 1 page long in the "classroom notes" section.
Yes. Though I might quibble that the set of [positive] periods is bounded below (by zero). But that lower bound is not member of the set. Accordingly, the set has no minimum element.
