Person dragging a bow with a rope - Calculate friction
  • Thread starter Thread starter dois
    Friction Rope
The discussion revolves around calculating the force exerted by a person dragging a 60 kg box, with an initial velocity of 4 m/s and a final velocity of 10 m/s over 3 seconds. Participants clarify that the coefficient of friction (0.7) relates to the frictional force, which is calculated by multiplying it by the normal force, equivalent to the weight of the box. The normal force is confirmed to be 60 kg, leading to a frictional force of 42 N. There is confusion regarding the difference between mass and weight, emphasizing the need for a solid understanding of these concepts. The conversation highlights the importance of using the correct equations to find the net force, factoring in both the applied force and friction.
dois
The question says
"A person is dragging a box with the mass of 60kg by a rope. The person begins to drag the box at 4 m/s [F]. All of a sudden the person sees on coming traffic. The person calculates that they have 3 seconds to get out of the way. If at the end of the 3 seconds the box is moving 10 m/s [F] and the coefficient of friction between the box and the ground is 0.7, find the force which the person is pulling the box."
my biggest problem is I don't know what a coefficient is.
im not to sure what equations i would need to use. My guess would be d=(vi)(t) + 1/2 (a)(t^2)
To find out the force which the person is pulling the box would we still use
F= m*a
and we would need to figure out the displacement first with d=(vi)(t) + 1/2 (a)(t^2)
The coefficient of friction, \mu is the constant relating the frictional force between two surfaces to the normal contact force between the two surfaces.
F_{friction} = \mu N​
The velocity of the box increases from 4m/s to 10m/s in 3s. I presume that should be enough for you to obtain the average force exerted on the box during this time period using the standard F=ma?
so μ is 0.7?
yep.
How would we begin this question
my known's are
mass= 60kg
vi=4 m/s [F]
v2=10m/s [F]
t= 10s
friction=0.7
but i don't know what equation to use to find the applied force
you have time, v0 and vf. from there, you must solve for acceleration, then plug it into F = ma , which will be your net force. From there, you must consider all the different forces and single out the pulling force. (Hint: the pulling force is not all that is affecting the pull.. what does friction do?)
my known's are
mass= 60kg
vi=4 m/s [F]
v2=10m/s [F]
t= 10s
friction=0.7
friction is not 0.7, that's the coefficient of friction. Friction is the coefficient of friction multiplied by the normal force
ok, and the normal force is equal to the mass right?
so then it would be
0.7 x 60
which would then be
42?
so then it would be
0.7 x 60
which would then be
42?
the normal force is what's keeping the object "up", it is the sum of vertical components.. so in this example, you only have the force of gravity or the weight pushing it down to the ground, so the normal force is equal to the weight
Alright. So then the normal force is 60, because the weight is 60kg.
and then friction would be, 0.7x60=42
is that right?
is that right?
no, mass and weight are two different things. I think that you should revise your concepts
