Perturbation Theory: Finding Eigenfunctions and Energies
PeteSampras
In a text a exercice says that for the Hamiltonian
##H_0 = \frac{p^2}{2m}+V(x)## the eigenfunction and eigen energy are ##\phi_n, E_n##. If we add the perturbation ## \frac{\lambda}{m}p## ¿what is the new eigenfunction?
The solution is
## \frac{p^2}{2m} + \frac{\lambda}{m}p+V= \frac{(p+\lambda)^2}{2m}- \frac{\lambda^2}{2m}+V##
but, the solution says ##\psi= exp(-i x \lambda/ \hbar) \phi_n##
I understand that ##H_0 \phi_n = E \phi_n## but,
¿why the solution ##\psi## has it form?,
Welcome to PF;
why [does] the solution, ψ, ha[ve] [that] form?
Perhaps because that is how the maths comes out?
Did you go through the calculation? Did you come up with anything else?
The form of the new psai is a phase factor mutiplied by the previous eigenfunction. You can to some extent anticipate this answer form because the moment p has undergone a certain 'shift' by lamda.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
