Phase difference between two points in a stationary wave
13 replies · 18K views
Janiceleong26
Q6c)
Why is the phase difference between two points in a stationary wave equals to zero?
I understand that a stationary wave is formed by two progressive waves which have the same amplitude, frequency, wavelength and speed, but traveling in opposite directions.
i hope you know that - every point on the string (in case of mechanical waves) is in simple harmonic motion
so for a string in resonance frequency (except fundamental) we have a part of the string moving with phase difference of ∏ (180°) with respect to the one adjacent to it (separated by a node).
Janiceleong26 said:
Q6c)
Welcome to PF Janiceleong26!
A standing wave with a node at x=0 and wavelength ##\lambda## is described by: ##y = A\sin(\omega t)\sin(2\pi x/\lambda)##. So the points on the standing wave between two nodes are all reaching their maximum and minimum at the same time. But what about points that are separated by a node?
AM
Hi, thank you for your reply.
I've not learn simple harmonic motion yet, but I understand that there is a part on the string moving antiphase to its adjacent part which are both separated by a node.
But how does that link to the phase difference being 0? The points P and Q in the picture attached are not separated by a node.
AM
Hi, thank you for the warm welcome.
How do the points in between nodes in a stationary wave reach their maximum and minimum at the same time? If you have a visual representation of this it'll be great. Points on a stationary wave is in antiphase with its adjacent part separated by a node. But how does that link to a phase difference of zero?
Start with: ##y = A\sin(\omega t)\sin(2\pi x/\lambda)##.
When do two points, not separated by a node and having x coordinates x1 and x2 respectively, reach their respective maxima for y? Answer: when ##\sin\omega t## is maximum ie. when ##\sin\omega t## = 1. Similarly, minimas are reached when ##\sin\omega t## = -1 This depends only on time and not on x. So they reach their respective maxima and minima at the same time. (those maxima and minima, of course, will depend on x - for a point (x1,y) the maximum value for y is ##y=A\sin(2\pi x_1/\lambda)## and for (x2,y) the maximum is ##y=A\sin(2\pi x_2/\lambda)##)
If they are separated by a node, what happens?
I don't think it does. How are the signs of ##\sin(2\pi x_1/\lambda)## and ##\sin(2\pi x_2/\lambda)## related when there is a node between x1 and x2?
AM
Ah I see, thanks. If the two points are separated by a node, then the points will reach their respective maxima / minima at a time difference of half a period, from each other?
So how does it link to question 6c)
This is the answer
Why a phase difference of zero?
This is the answer
Are the two points P and Q separated by a node?
AM
AM
No, they are not.
Janiceleong26 said:
No, they are not.
So they reach their maxima and minima at the same time as explained in my post #6 - ie. no phase difference. If they were separated by an odd number of nodes, they would be ##\pi## radians out of phase.
AM
AM
I see, thanks. But the two points in the question paper have different maxima / minima.. Do they still reach their respective maxima / minima at the same time too ?
The maxima and minima will depend on x but they will occur at the same time ie. when ##\sin\omega t## = 1 and -1. See my post #6.
AM
AM
Got it. Thank you very much !
I have been searching everywhere for a simple diagram showing the way the phasors of incident and reflected wave but I have failed. What I want (for someone else!) to show is how the incident and reflected waves, starting with the antiphase condition at the reflecting wall . They will cancel. Imagine one phasor pointing up and the other pointing down. Then, as you move away from the wall, a graph of the phasors against distance will show them each rotating at the same rate but in opposite directions, producing a resultant that always lies on a horizontal axis on the phasor diagram. So the resultant standing wave will always have the same frequency and phase, all the way along the string.
But I think there is a more fundamental reason. That is, the system is linear and cannot generate any frequencies other than the input frequency and that applies to spatial as well as temporal variations. Changing the relative phase would have to imply frequency variation and so the phase of the resultant would have to be the same all the way along the string.
