Phase difference in CR and LR circuits
The discussion revolves around an experiment with CR and LR circuits, focusing on the phase difference between voltage and current. Key questions include the rationale for connecting the CRO channels across both the capacitor and resistor, the observed current through the capacitor, and the effects of varying resistance on phase difference. Participants suggest using phasors to analyze the problems, emphasizing the importance of understanding the relationship between voltage and current in these circuits. The phase difference is noted to change with resistance adjustments, and the impact of replacing the capacitor with an inductor is also explored. Overall, the thread highlights the complexities of phase relationships in CR and LR circuits and encourages deeper investigation into the observed phenomena.
cash200107
I have just done an experiment on CR and LR circuits.
http://img9.picsplace.to/img9/21/RC.jpg
Connect channel 1 of the CRO across both the capacitor and resistor and channel 2 across the resistor.The trace on channel 1 is taken as the p.d. across the capacitor and that on channel 2 as ths current throught the capacitor.
http://img9.picsplace.to/img9/21/RL.jpg
Replace the capacitor waith a high inductance coil fitted on a double C-core.
I have some questions about this.
1.Why is channel 1 is connected across both the capacitor and resistor and not only the capacitor?
2.Why the trace on channel 2 gives the current through the capacitor?
3.When we increased the resistance value, the phase difference decreased.Why?
4.what is the phase difference between the p.d. and the current?
5.Change the resistance value and observe how this affects the phase
difference.Describle and explain the change,if any,in the phase difference.
6.Replace the capacitor with a high inductance coil fitted on a double c-core.Observe the CRO traces and note the phase diff between the p.d. across the inductor and the current through it.What is the phase diff. between the p.d. and the current?Why is it not 90°? How to sketch the CRO traces?
7.Change the resistance value and observe how this affects the phase difference.Describle and explain the change, if any, in the phase difference.
I have so many question to ask ..:cry:
I'm not going to do your homework for you. What, specifically, do you need help with?
Phasers seem like the way to go with this type of problem, though since there isn't anything numerical you don't necessarily have to.
