Find w For AC RLC Circuit When Emf is In Phase With Current
  • Thread starter Thread starter scorpius1782
    Phase
scorpius1782
I have an AC RLC circuit with the inductor in series with parallel capacitor and resistor.
At what w is the emf in phase with the current?
I'm suppose to know this from a previous class but as a transfer student my classes never dealt with phase or RLC circuits. Any help would be phenomenal.
The question is specifically asking if ##w=\frac{1}{\sqrt{LC}}##
What exactly within an electrical system causes the phase of the current to differ from the phase of the voltage?
The inductor resists changes in current so voltage changes happen more quickly and vice versa at the capacitor. (I just discovered ELI the ICE man). So, would this mean that the peak would happen every 90 degrees? How would I relate the angle to w?
The phase of the current will differ from the phase of the voltage if there is reactance present within the network. If the voltage and the current are completely in phase with one another, it implies that the load is completely resistive (imaginary portion of the impedance is zero). Do you know how to calculate the impedance of a capacitor and inductor?
I see you found my other post! I'll discuss this there.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
