Phase relationship at high frequencies
The discussion revolves around the phase relationship between input and output voltages at high frequencies for a given transfer function. Participants explore the implications of high-frequency behavior, particularly in relation to phase shifts introduced by poles in the transfer function.
  • Homework-related
  • One participant initially calculated the phase at very high frequencies to be 0°, questioning the discrepancy with the teacher's answer of -180° due to the presence of two poles.
  • Another participant suggested substituting jω for s to analyze the phase angle, noting that j corresponds to +90 degrees and exploring the implications of j².
  • Some participants agreed that the formula was correct but expressed confusion over why substituting ω as infinity did not yield -180°.
  • One participant advised keeping the x and y components separate rather than forming a ratio for the arctan function, suggesting that this could clarify the phase behavior as frequency increases.
  • There was a query about whether higher frequencies could be assumed to be above the cutoff frequency, to which a participant confirmed that this assumption is valid.
  • Another participant noted that the phase approaches -180° at very high frequencies but never actually reaches it, suggesting the use of tools like Bode Plot for further analysis.
Participants express differing views on the calculation of phase at high frequencies, with some supporting the teacher's answer of -180° while others remain confused about the methodology leading to that conclusion. The discussion does not reach a consensus on the correct phase value.
Participants highlight the ambiguity in the arctan function and the behavior of the phase as frequency approaches infinity, indicating that assumptions about frequency ranges and pole contributions may affect the results.
roinujo1
Given the transfer function:
Find the phase relationship between the input and output voltage at high frequencies
NA
My approach was to find the phase of the transfer function, which I got to be:
I assumed that "very high frequencies" meant w = ∞, plugging it in, I get the answer to be 0°.
However, the answer from my teacher was that it was -180, because the transfer function had 2 poles, each at -90. While I can understand this, I wanted to know why my method was wrong.
[/B]
Try substituting j*w {j is imaginary, and w is omega} for s and then see what the angle becomes. So j is equivalent to +90 degrees. 1/j = -j is equivalent to -90 degrees. So what does j^2 do? (or 1/j^2) What angle would that approach? This is how Bode plots (phase) can be made, if you are familiar with them.
I rather think, the questioner has already replaced s by jw while deriving the formula as given in 3) .
And - yes - the formula is correct. Hence, there is nothing left than to evaluate the formula for very large frequencies (considering that the arctan function is not unambiguous).
Yes; this is what i was hoping to do. However, plugging w as infinity does not get the -180, so I am confused.
Keep the x and y components separate rather than forming the ratio y/x for the arctan function. That means retaining any signs associated with them rather than letting them get entangled in the ratio. Then evaluate by inspection how those components will trend as ω gets larger, and where the vector (x,y) formed from them is headed.
I think this works well. I got the awnser I was looking for. Thank You!
Just another question. Can higher frequencies be assumed that frequencies higher than the cutoff frequency?
Yes.
Thank you !
That is a good question, because it never will actually get to -180 degrees. It approaches that at very high frequencies (much higher than the cutoff). Wolfram Alpha has a nice tool (search for Bode Plot) and you can type in the transfer function and see both the gain plots and phase plots.
  • · Replies 16 ·
