Are Photons Truly Particles or Simply Waves?
barquentine
I really don't believe that photons can be particles.
Supposedly the photoelectric effect "proves" they are.
I believe that electrons are emitted as a result of short-distance penetration of the wave front into the metal, disturbing the bonds. This would also fit the known fact that the frequency of light must be above a certain value or electrons are not emitted. I'm betting that the minimum frequency corresponds to the longest wavelength that can "fit between" the lattice structure.
Comments please?
Comments please?
You need to explain the which-way experiment and the photon antibunching experiment before you settle into your "belief".
Zz.
Zz.
Please provide references.
I've provided references to these many times over on here. You're welcome to do a search in the QM forum (where this should have been posted in the first place). Furthermore, aren't you a bit worried that you are not aware of such experiments, yet you have no problem with making outright statements with such confidence? One normally has to do a lot of "homework" first to make sure one knows everything there is to know out there before proclaiming something.
Example of which way experiment: J.J. Thorn et al. Am. J. Phys. v.72 p.1210 (2004).
Example of antibunching experiment: any single-photon sources paper or H. Paul, Rev. Mod. Phys. v.54, p.1061 (1982).
Example of multiphoton photoemission: K. Giesen et al., Phys. Rev. Lett. v.55, p.300 (1985); W.S. Fann et al., Phys. Rev. B v.44, p.10980 (1991).
Zz.
Comments please?
I'll take that bet. How much you want to make it?
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
