Is the Photoelectric Effect an Ideal Heat Sink for Photovoltaic Cells?
In summary, the photoelectric effect occurs when an incident photon's energy is higher than the band gap of the silicon used for the cell, and this produces a voltage. A heat sink is not an ideal solution because it only converts a fraction of the incident energy into electricity and it's not physical because it violates a rule of thermodynamics.
Smacal1072
59
Hey all,
First off, thks to everyone here on physicsforums, this is such a great resource for anything physics-related.
I was thinking today about the photoelectric effect, and a scenario popped into my head which seemed counter-intuitive. Please correct me if I'm wrong, it's been a while since I've been at the University:
Photovoltaic cells utilize the photoelectric effect to produce a voltage whenever an incident photon's energy is higher than the band gap of the silicon used for the cell.
All matter above absolute zero emits thermal radiation, and the energy of the radiant photons is distributed by Planck's law. Planck's law implies that at all (even very low temperatures) high energy photons are radiated. Let's assume I throw a photovoltaic cell in an isolated physical system that is above absolute zero. Assuming that the voltage produced is being utilized outside of the system, how is this not an ideal heat sink?
It is not ideal because it only converts a fraction of the incident energy into electricity. But yes, if, for example, you don't connect a solar panel to anything that will dissipate the electrical energy, it will get hotter than if you do.
Also, I'm not sure if there is such a thing as a heat sink that operates by absorbing radiant heat. I can't fathom an application for such a thing.
I'm sorry, I appreciate your response but I think I've neglected to mention that in this scenario the solar cell is connected to a load outside of the system (or even inside the system). Maybe it drives a tiny motor, which raises a tiny weight. Or it's charging an ideal capacitor, with infinite capacitance. Or it's electrolyzing water. Anything but converting it back to heat.
And I also have to apologize: heat sink is the wrong word (it's been a while since thermo 101). I was trying to express that the cell is converting a portion of the heat energy in the system to a scalar potential (by way of radiant radiation). So, it's reducing the overall temperature of the system. In a roundabout way it is a thermoelectric transducer.
My point of confusion is this: How can this system be physical? It's breaking a rule of thermodynamics (it's reducing the entropy of the system by being a heat engine without a cold reservoir).
I appreciate your help!
This is an interesting question. Suppose we have an isolated system, meaning an ideal evacuated isolated black box at say 293 kelvin with a photovoltaic cell inside, and the band gap were very small, so the photocell could detect far infra red (including part of Planck spectrum). We further assume that the photocell is at equilibrium with the box. Now, attach wires to the photocell, and draw current through the wall of the black box. Does the temperature inside the black box drop?
Thks Bob that summarizes the problem much better.
Assuming this situation is possible, the only thing I can imagine is that the system becomes more and more negatively ionized as we use the photocell's current, since electrons are ejected from the cell by the photoelectric effect. Maybe once it becomes ionized enough it reaches an equilibrium?
But even if this is the case, it isn't really a satisfactory answer - we've just made another problem because we've spontaneously ionized the system.
No, you did say that. I was showing the difference between the two scenarios to confirm/emphasize your point.
You started another thread asking the same question. The answer is simply that you are violating your system boundary. You are analyzing the situation incorrectly. Draw the boundary around the entire system: the sun, the PV cell, and the electrical load, and you will see that the system does not spontaneously decrease its own entropy.
Assuming this situation is possible, the only thing I can imagine is that the system becomes more and more negatively ionized as we use the photocell's current, since electrons are ejected from the cell by the photoelectric effect. Maybe once it becomes ionized enough it reaches an equilibrium?.
My system assumed that all the current (or electrons) on one wire returned on the other wire, so no net charge left or entered the system. No net charge either left or returned to the photocell. But energy was being extracted from the system and dissipated on a resistor outside. So where did the energy come from?.
Charge is simply a carrier for energy, like water in a dam, steam in a steam engine, etc. It transfers energy when you move it around. The energy to move it in this case came from the sun.
A photocell at thermal equilibrium with its surroundings will not get power from the surroundings. Remember, a photocell is a semiconductor junction, and when a semiconductor's band-gap is on the order of the temperature times k then the photocell short circuits due to thermal leakage current. Roughly it works out that a photocell won't really get power from a blackbody unless it is more than 3 times hotter than the photocell. So in a photocell you always have energy going down the temperature gradient, consistent with the 2nd law of thermo.
Oops, missed that part...
That would explain it - thks DaleSpam
Russ - You're right I did start another thread on this topic...I apologize but I was so curious! I was afraid this thread appeared resolved. I do appreciate your replies
So would this mean that cooling a solar cell down to very low temperatures would increase its efficiency?
Sounds like that's the case
This makes sense, but I just thought of this today: The band gap of Si is about 1.11 eV at 300K. It maxes out at 1.2 eV as Si is cooled to 0 Kelvin, and decreases as it's heated. A photocell begins to short circuit when kT approaches the band gap energy right (T here is ~ 10,000K)? So long as a photocell is below this temperature, short circuiting does not arise?
Yes! You should be able to find temperature vs efficiency curves for commercially available solar cells via google.
It is not a sharp cut off like that. Remember that the Boltzmann distribution has some pretty large tails. Also, don't forget that there are a lot of holes, so even a relatively minor fraction of them can easily swamp the small photoelectric current.
1. How do photovoltaics act as heat sinks?
Photovoltaic cells absorb sunlight and convert it into electricity. This conversion process also results in the dissipation of heat, making the photovoltaic system act as a heat sink.
2. Can photovoltaics reduce the overall temperature of a building?
Yes, photovoltaic systems can reduce the overall temperature of a building by providing shade and absorbing heat that would otherwise be transferred into the building. This can result in lower cooling costs and improved energy efficiency.
3. Do photovoltaics release heat into the environment?
Yes, photovoltaic systems do release some heat into the environment as a byproduct of the conversion process. However, this amount of heat is negligible compared to the amount of heat that would have been generated by traditional energy sources used to produce the same amount of electricity.
4. Can photovoltaics overheat and become less efficient?
Yes, photovoltaic cells can overheat if they are not properly maintained or if they are installed in areas with high ambient temperatures. This can result in a decrease in efficiency, but it can be prevented by proper maintenance and installation techniques.
5. Are there any benefits to using photovoltaics as heat sinks?
Yes, there are several benefits to using photovoltaics as heat sinks. These include improved energy efficiency, reduced cooling costs, and a smaller carbon footprint compared to traditional energy sources. Additionally, photovoltaic systems have no moving parts, making them low maintenance and long-lasting.
  • Materials and Chemical Engineering
  • Electromagnetism
  • Electromagnetism
  • Quantum Physics
18K
