Physical Difference in a Cepheid Variable
Cepheid variables differ from normal stars primarily in their gas temperature and pressure conditions, which affect how they absorb energy. This unique absorption leads to a cyclical pulsation mechanism, where the expansion and contraction of the star create a feedback loop similar to a piston engine. The specific period-luminosity relationship observed in Cepheid variables is understood to stem from this pulsation cycle, although some details remain unclear. As the star expands, the density decreases, reducing its ability to absorb radiation, which ultimately influences the heat dynamics during pulsation. This complex interplay of absorption and heat release contributes to the star's oscillation amplitude until it reaches a saturation point.
Vorde
What is the physical (i.e. molecular/chemical) difference between a normal star and a Cepheid Variable? Do we know and if so can we explain what gives rise to the specific period-luminosity tie?
Thank you.
Astronomy news on Phys.org
Did you read the Wikipedia article? If not, you should. If so, what didn't you understand?
The gas in a Cepheid variable is at a particular temperature and pressure so that if you heat the gas it absorbs more energy, which is different from the usual relationship.
So you end up with more heat -> more absorption -> more heat until you move out of that condition.
We think we know the basic mechanism, but there are still some open questions about the exact details.
http://astro.if.ufrgs.br/text/saioannurev.pdf
There's another wrinkle to the basic explanation that should probably be mentioned. The pulsations are cyclical, they are not just a shift to a new equilibrium in which the instability goes away. To be cyclical, there must be a restoring mechanism to go with the unstable mechanism. The restoring mechanism is that once the star expands sufficiently, the mechanism that was allowing it to expand (the absorption of heat by absorbing radiation by bound electrons in metals) eventually short circuits, because once the star expands enough, the density drops and the ability to absorb radiation also drops. So the heat that was absorbed early in the cycle is released late in the cycle. This has the net effect of adding heat when the gas is compressed, and releasing it when the gas is expanded. Sound familiar? That's how a piston engine works! If you add heat when compressed, and release it when expanded, you create a cycle that does a net amount of PdV work. This work will go into pumping up the amplitude of the oscillation, until it reaches some kind of nonlinear saturation when irreversible mechanisms kick into dissipate the work. Often, transporting heat across a temperature difference is the best dissipation mechanism. So when the driving layer of the oscillation is no longer at the same temperature, heat transport within the gas will dissipate the work being input, and the amplitude saturates.
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
