What is the maximum distance a stone thrown at 30 m/s can cross a river?
To determine the maximum distance a stone thrown at 30 m/s can cross a river, the discussion focuses on calculating the time of flight and the horizontal distance traveled. The initial attempt yielded a time of 5.2 seconds, leading to a distance of 156.3 meters, which is incorrect. Participants suggest deriving the Range Equation and using the launch angle to maximize distance, specifically at 45 degrees. Calculations involving horizontal and vertical components of the initial velocity are emphasized, with some discrepancies noted in the time and distance results. The correct approach involves recalculating time and applying the appropriate equations for maximum range.
roxxyroxx
A stone is thrown at 30 m/s. what is the widest river it can be thrown across? (the stones ends at the same vertical height from where it was thrown)
x=vxot
y=vyot + 0.5gt2
i know i need to find t first. using the second equation i got t as 5.2s. when i multiplied 5.2s by vxo (30m/s) i got 156.3 m but the answer should be 92m. wat did i do wrong?
You can't just use the V as Vx.
Vo is constrained to be 30 m/s.
I rather think they want you to derive the Range Equation and determine where range reaches its maximum.
Using your equations then, and
Vox = Vo*Cosθ
and
Voy = Vo*Sinθ
derive an expression for X, total distance, and then determine at what angle of launch you get the maximum.
Along the way you might find this useful ... 2*Cosθ*Sinθ = sin(2θ)
well when i used x=vxot
i put in (30cos45)(5.2s) but i got 82m instead of 92 m
You maybe want to recalculate.
I get a different time which is less and the answer given - after rounding.
how did u get ur time?
i can't seem to get any other answer than what i got..
v = g*t
t = v/g
That's time to max. Double it to come back down.
v = 30*sin45 = 30*√2/2
30*√2/2*2/g = 30*√2/g = ... ?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
