Calculating Average Force for a Baseball Batting Exercise
To calculate the average force acting on a baseball during a batting exercise, the correct formula is Fnet = mv/t, where m is the mass in kilograms, v is the final velocity, and t is the time of contact. The mass of the baseball is given as 145 g, which should be converted to 0.145 kg for accurate calculations. Using the values provided, the average force can be calculated as Fnet = 0.145 kg * 84 m/s / 0.09 s. The initial calculation of 135,333.3 was incorrect due to the mass not being in the proper unit. The final answer should be expressed in Newtons for clarity.
astru025
Physics average force need help!
A coach is hitting pop flies to the outfielders. If the baseball (mass = 145 g) stays in contact with the bat for 0.09 s and leaves the bat with a speed of 84 m/s, what is the average force acting on the ball?
Fnet=mv/ t
Fnet= 145 x 84 / .09
I got 135333.3 and this wa incorrect. I think I am using the wrong equation... Please help!
Problem looks like units, assuming you were supposed to give your answer in Newtons. If you want the force in Newtons, you need the mass to be given in kg.
Thank you very much!
