Physics ELECTRON IN THE ATOM presentation
To effectively present on the role of electrons in an atom, using visual aids such as models of different atoms can enhance understanding. A hands-on approach, demonstrating how electrons interact within various atomic structures, is recommended for clarity. Explaining the significance of electrons in chemical reactions can further illustrate their importance. Since the presentation is brief, focusing on key concepts and engaging visuals will help convey the information effectively. Overall, a clear and interactive presentation will aid classmates in grasping the atomic nature of matter.
Sithlord586
Yes i have to present how an electron in an atom works. I also have to present an example of how it works. IS there anything i can do up on presentation to show how an atom works? IF not an example can someone help me with a concept map? So that I may explain it to the class? ANything that is a visual aid to the class. It is a requirement. I can't quite come up with an example or a visual to show the class what i mean. PLease help if you can. Thank you.
And what exactly do you have in mind??I mean what are u going to show them?
What are your ideas...?
Daniel.
Well i was planning on showing the class what an electron's role in an atom is by using visual aids..since i have to anyway. I'm also having trouble with this chapter as well so in the process i was wondering if you can help clarify what electrons do in an atom and a way i can show the class the whole general idea of the electrons in the atom. the presentation is only 5 minutes so i just need something i can say and show.
I don't really know all the important points to say i want to say the main points. I was wondering if you can help me show that and say that.
"class",are you in high school?
Daniel.
Yes i am. I am in 11th grade , a junior , in high school.
Science is not my best subject but a requirement and my last year of taking a science subject.English is my best and history. My skills in science and interest are not that high. But still while I am in physics i wish to learn. Chapter 17 we are doing which is " atomic nature of matter". Each student was given a certain sector in the chapter. I was given 17.8 " Electron in the atom". So obviously i have to consist of what everyone else. Is there any chance you may help me?
(Please pardon any slightly butchered English in advance...thank you. :wink: )
I would say that the best thing you could in a high school class is explain it on a level most people would understand, probably using some sort of a model. If you just show them a plain text chart, they'll probably forget, but if you present a working model of several different atoms and make it a hands-on report, I think the class will understand it better.
Also, I would suggest buildng several different models of different atoms and explain how the electrons help them interact. (That is, in essence, what electrons do.) Perhaps showing the class what role electrons play in chemical reactions would help them understand the importance of the electron in relation to the atom.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
