Calculating Loss Tangent and Poynting Vector for Electromagnetic Waves
  • Thread starter Thread starter unstoppable
unstoppable
Hi can someone help me out with these questions? I would greatly appreciate it!
1) A source of unidirection plane waves operates within a medium with moderate conductivity sigma. Suppose we measure the complex electric field amplitudes at the source and at some distance z and find that E(z)/E(0)-0.3-j0.4.
(a) Calculate the loss tangent sigma/(omega*epsilon) of the medium. (Give a numerical value)
(b) What is the ratio of complex magnetic field amplitudes H(z)/H(0) for the same z?
2) A perfect planar mirror in the xy-plane has normally incident and reflected electromagnetic plane waves in the vacuum region z<0 in front of it, at frequency omega. The magnetic field at the mirror surface is circularly polarized:H=H(x + jy)
(x and y are the unit vectors along x and y).
(a) Find the complex electric field amplitude E(z) in the space z<0.
(b) Find the complex Poynting vector(give magnitude and direction) in the space z<0.
2. Homework Equations
equation for phase velocity: Vp=Vp(omega)=omega/k= c*omega/squarerootof(omega^2-omega^2) Note: The second omega^2 is the cuttoff frequency
equation for group velocity: Vg=Vg(omega)=c*squarerootof(omega^2-omega^2)/(omega)
Note: The second omega^2 is the cuttoff frequency.
c=the speed of light 3 X 10^8 m/s
Circular Polarization: E(0)=Eox=1/2Eo(x+jy) +1/2Eo=(x-jy)
Note: j=the imaginary complex number
E(z)=1/2*Eo(x+jy)*e^-j(ko+K)z+1/2*Eo(x-jy)*e^-j(ko-K)z
Poynting Vector: The Vector E X H is the Poynting Vector. It gives the power per unit area that flows at a point;
Loss Tangent:Theta/(omega*epsilon)
Hi unstoppable! :smile:
(have a theta: θ and an omega: ω and an epsilon: ε :smile:)
Show us what you've tried, and where you're stuck, and then we'll know how to help. :wink:
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
