Physics Kinetic Energy Question
When comparing the heights reached by two identical cannonballs shot straight up with different initial velocities, the conservation of energy principle applies, where total energy equals kinetic plus potential energy. The first cannonball, having 2.0 times the initial velocity of the second, will reach a height proportional to the square of its velocity, leading to a height increase of four times compared to the second cannonball. As the cannonballs ascend, their kinetic energy converts to potential energy until they momentarily stop at their peak height. To solve for the final position, kinematic equations involving initial and final velocity, acceleration due to gravity, and displacement should be utilized. Understanding these concepts and equations is crucial for accurately determining the heights achieved by each cannonball.
Ion1776
You are about shoot two identical cannonballs straight up into the air. The first cannonball has 2.0 times as much initial velocity as the second. How many times higher will the first cannonball go compared to the second?
How do you do this
Total energy = Kinetic + Potential in this scenario, right? Also note that the energy is conserved (well, assuming no air resistance)
As each ball travels higher into the air the potential becomes larger, which means the kinetic energy decreases until all the energy is potential. This is where each ball will stop.
Does this help?
So what formula should I used, how should i plug the numbers in
I actually don't think you need kinetic energy for this... Try using kinematics equations.
How about helping me out, and showing me how to do this.
I know my equations, I don't know what to use, plus I need to understand the concept...
Well, since they're both shot straight up, the only acceleration you need to worry about is gravity. Find an equation with only initial and final velocity, acceleration, and displacement. Set the equations equal to each other. Solve for final position.
Sorry, there's really not too much more I can say without giving you the work, and the point is just to point you in the right direction.
