Physics/mechanics, forces accelaration
A ball thrown horizontally from a height of 18 meters at a speed of 5.0 m/s takes approximately 1.92 seconds to hit the ground, which is close enough to the expected 2 seconds. The calculation used the equation S=ut+1/2at^2, with an initial vertical velocity of 0 and gravitational acceleration of 9.8 m/s². The horizontal motion does not affect the time it takes to fall, as the two components of motion are independent. The horizontal speed will be relevant for determining how far from the window the ball lands. The discussion confirms the accuracy of the method used to arrive at the solution.
gaz3992
A ball is thrown horizontal out of a window 18m above the ground. it is thrown horizontally at 5.0ms. show that it takes about 2 seconds to drop.
S=ut+1/2at^2
u=0
a=9.8
s=18
18=0t+1/2*9.8t^2
36=9.8t^2
sqrt3.6734=t
t=1.92
is this near enough too 2 to be the right answer or have i made a mistake some where i was not sure if the horizontal force would have any effect on the time taken to drop. Any help would be much appreciated.
That's perfect. 1.92 is certainly "about 2 seconds" in anyone's book!
The horizontal component of the ball's motion is independent of the vertical, gravitational, component; so your method is fine.
(That horizontal velocity of 5m/s doesn't come into this calculation, but is probably needed for further calculations, such as how far away from the window does the ball land?)
Oh, and welcome to Physics Forums!
Thanks i just needed conformation because i got to the answer partially using trial and error to find the right method and I'm impressed you managed to guess the exact next question on the paper.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
