Physics Problem, cant find mistake, okz help
  • Thread starter Thread starter Ion1776
    Mistake Physics
The physics problem involves calculating the average net force on an 85.0 kg stunt double who falls 12.0 m and takes 0.477 s to stop upon landing. The initial speed upon impact is calculated to be 15.3 m/s, leading to an acceleration of -32.1 m/s² required to stop her. The resulting force is calculated as -2.73 kN, but it is suggested that this force should be considered positive, as it acts upward to decelerate her. The calculations using both kinematics and the impulse-momentum theorem yield consistent results. The discussion emphasizes the importance of sign conventions in force calculations.
Ion1776
Here is the Problem: For a movie scene, an 85.0 kg stunt double falls 12.0 m from a building onto a large inflated landing pad. After touching the landing pad surface, it takes her 0.477 s to come to a stop. What is the magnitude of the average net force on her as the landing pad stops her?
IS THIS CORRECT, wheres the mistake?
First, find the speed of the stunt woman as she hits the landing pad:
v² = v₀² + 2gΔy
= 0 + 2(-9.80m/s²)(-12.0m)
v = 15.3m/s
Now, the rate of acceleration required to bring her to a stop is:
a = Δv / Δt
= (v - v₀) / t
= (0 - 15.3m/s) / 0.477s
= -32.1m/s²
So, the force that stops her is:
F = ma
= 85.0kg(-32.1m/s²)
= -2.73kN (-2730N rounded)
You could also use the impulse momentum theorem:
FΔt = Δp
F = Δp / Δt
= [mv(f) - mv(i)] / t
= m[v(f) - v(i)] / t
= 85.0kg(0 - 15.3m/s) / 0.477s
= -2730N (rounded)
Please give a through answer
v² = v₀² + 2gΔy
v = 15.3m/s
a = Δv / Δt
= (v - v₀) / t
= -32.1m/s²
F = ma
= 85.0kg(-32.1m/s²)
FΔt = Δp
F = Δp / Δt
= -2730N (rounded)
Your first method looks okay to me (didn't check the 2nd). I would call the force positive, though, since it's pointing up to decelerate her...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
