Physics Problem (densuty, pressure etc)
  • Thread starter Thread starter shalei
    Physics Pressure
The discussion revolves around solving various physics problems related to density and pressure. The first question involves calculating the tension in a string holding a wooden block submerged in water, requiring an understanding of specific gravity and buoyancy. The second question focuses on determining the pressure at the bottom of a test tube containing oil and water, emphasizing the total weight of the fluids and the cancellation of the cross-sectional area in calculations. The third question examines the change in blood pressure when a woman bends over, highlighting the assumption of constant pressure at the heart and the need to consider the height difference. Lastly, the fourth question compares the weight of an iron ball in water versus alcohol, suggesting that the ball will weigh more in the liquid with lower density due to buoyancy effects.
shalei
1. A block of wood weighing 105 N and of specific gravity 0.75 is tied by a string to the bottom of a tank of water in order to have the block totally immersed. What is the tension in the string?
2. A vertical test-tube has 2 cm. of oil (density= 0.80 g/cu. cm.) floating on 8 cm. of water. What is the pressure at the bottom of the tube due to the fluid in it?
3. A standing woman whose head is 35 cm. above her heart bends over so that her head is 35 cm. below her heart. What is the change (in torr) in the blood pressure in her head?
4. In which liquid will an iron ball weighing 20 N weigh more in water or in alchohol? By how much?
Please help my friend? Even if you don't want to answer some of them, will you please help us? :smile:
Oh, I'm new here but not new at lurking..
4: any liquid with a higher density perhaps mercury there will be a bigger upthrust from the pressure in the liquid than in water, at a certain height the ball should be able to weigh 20N at the same height in water the upthrust would be less so the ball would weight more, just a guess though
The upthrust on a body immersed, or partially immersed in a liquid is equal to the weight of the liquid displaced.
So, the first question. You need to work out how much a volume of water equal to the volume of the wood weighs. The specific gravity = 0.75 means that the wood is 3/4 as heavy as the same volume of water, so the water would weigh 4/3 as much as the wood. The upthrust pushes the wood up, and you have to subtract the weight of the wood to get the resulting string tension.
The second question. Add the weight of the water to the weight of the oil to get the total weight in the tube. Divide that by the area of the bottom of the tube to get the pressure. Now you don't know the cross sectional area of the tube, but you can just call it A, and you'll find that it will cancel out and disapear from the final answer. As the value of A doesn't make any difference to the final result, you can set A=1 to make the math easier.
Question 3. This is a bit of a dumb question, as there is the hidden assumption that the blood pressure at her heart remains constant, which it might not do. Also they don't tell you the density of blood, so I guess they want you to assume it is the same as water. What it seems they're really asking you to work out is the pressure at the bottom of a 70cm (35 + 35) column of blood (or water).
Question 4. Ask yourself whether an Iron ball weighs more in air than it does underwater. That should give you a clue on how to work out the answer.
