- 7,207
- 25
Oops ! Misunderstood the notation. M = M1 + M2 (I guess), so that's fine ! Sorry.
nishant said:Ok,so The Main Thing U Want To Ask Is In Which Way Do Thay Collide?
whozum said:I was going to, but I don't really understand the question. Do they suffer some kind of deformation? If they combine, then their radius will be the sum of both their radii, or do they ocmbine into a single spherical body?
Imagine the particles interact only with the B-field, and not with each other. Determine their trajectories. You will find that, at some particular time, they will both be found at the same point. This event defines their collision. From this instant on, they continue as one single particle.nishant said:the necessary condition should be giving the way they collide.
Stefan Udrea said:![]()
Ok,here's the problem :
There are 2 towns on the surface of the Earth, the distance between them is thousands of kilometers.
There is a *straight* tunnnel digged from one town to the other,and a railway in the tunnel.
Show that the train ,which circulates throough the tunnel between the two towns ,doesn't need a ... locomotive.
Neglect the frictions.
(edited to make it bold )
Stefan Udrea said:jdavel, this is too simplistic.Where do you draw the line of zero potential energy ?
jdavel said:The customary location to define zero potential is at infinity. But I don't see what difference it makes. As long as the PEs at the beginnning and end of the tunnel are the same, no energy is used getting from one to the other. What am I missing?
Galileo said:The work done on getting the train from A to B may be zero, but that doesn't mean no locomotive is needed. There might be a potential barrier in between which the train cannot cross.
Stefan Udrea said:extreme_machinations,
Because you were the closest to find the solution, you get to ask the next question.
Stefan Udrea said::smile : don't call me "sir" , I'm just a college student.
jdavel,
In the drawing,
AB is the tunnel , the two cities are in A and B.
T is a random position of the train in the tunnel, at the distance r from the center of the Earth ; r<R
Because the volume of the Earth between r and R has no gravitational influence on the train, we have the gravitational attraction on the train F=kmM/r^2 , where M is the mass of the sphere of radius r.
M_0is the total mass of the Earth
M=M_0 \frac{r^3}{R^3}
The movement of the train is given by the component F_e ,parallel with the tunnel.
Then,
F_e=K \frac {m M_0}{R^3} y =ky
\vec{F_e}=-k \vec{y}
So the movement in the tunnel is a harmonic oscillation given by :
y= \sqrt {R^2-d^2}sin(\omega t+\frac{\pi}{2} )
y=w \sqrt{R^3-d^2}cos(\omega t+\frac{pi}{2})
T_0=2 \pi R \sqrt{\frac{R}{KM_0}}
jdavel said:How about making the top mass of the triangle and the incoming mass both equal to M/2?![]()
