Is the Calculation of the Bird's Average Acceleration Correct?
  • Thread starter Thread starter RS7
    Physics
The discussion revolves around calculating a bird's average acceleration based on its velocities at two positions and the time taken to travel between them. Initial calculations yielded an average acceleration of 0.41 m/s² at 17 degrees N of E, but concerns about the signs of the velocities prompted a reevaluation. After correcting the signs, the revised average acceleration was found to be 0.8 m/s² at 60 degrees N of E. Participants emphasized the importance of defining positive directions for velocity components to ensure accuracy. The final consensus suggests that the recalculated values are correct.
RS7
Physics question, solved but need clarification!
A bird take 8.5 s to fly from position A to position B. Determine the bird's avg acceleration
Vb = 7.8 m/s [25 degrees N of E]
Va = 4.4 m/s [ 31 degrees S of E]
Vax/Va = cos31
Vax/4.4 m/s = cos31
3.8 m/s
Vay/Va = sin31
Vay/4.4 m/s = sin31
2.3 m/s
Vbx/Vb = cos25
Vbx = 7.8cos25
7.1m/s
Vby/Vb = sin25
Vby= 7.8sin25
3.3m/s
Ay = Vby- Vay / t
3.3-2.3/ 8.5 s
0.12 m/s^2
Ax = Vbx- Vax / t
7.1 m/s - 3.8 m/s / 8.5 s
0.4 m/s^2
a^2 = Ax^2 + Ay^2
0.16 + 0.0144
0.174 m/s^2 and then you square root it 0.41 m/s^2
tantheta = Ay/Ax
0.12 m/s^2/0.4 m/s^2
0.3 = 17 degrees
The bird's avg acceleration is 0.41 m/s^2 [17 degrees N of E]
I just need to make sure if I did this right, if anyone would clarify this that would be great!
thanks
Welcome to PF :smile:
It's mostly correct. You'll want to recheck +/- signs for the velocities. Is Northward or Southward the "positive y" direction?
oo then if I messed up on the signs I guess my answer is wrong, and northward is the positive y direction I think
Vax/Va = cos31
Vax/4.4 m/s = cos31
3.8 m/s
Vay/Va = sin31
Vay/4.4 m/s = sin31
- 2.3 m/s
Vbx/Vb = cos25
Vbx = 7.8cos25
7.1m/s
Vby/Vb = sin25
Vby= 7.8sin25
3.3m/s
Ay = Vby- Vay / t
3.3 + 2.3/ 8.5 s
0.7 m/s^2
Ax = Vbx- Vax / t
0.4 m/s^2
a^2 = Ax^2 + Ay^2
0.16 + 0.49
0.65 m/s^2 and then you square root it 0.8 m/s^2
tantheta = Ay/Ax
0.7m/s^2/0.4 m/s^2
1.75 = 60 degrees
the bird's avg acceleration is 0.8 m/s^2 [60 degrees N of E]
is this right? :S
I used the signs for the velocities but not quite sure if I did it right...
Looks good. :smile:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
