What is the speed of the second stage after separation?
  • Thread starter Thread starter MightyMan11
    Physics Rocket
The discussion revolves around calculating the speed of the second stage of a two-stage rocket after separation, using the conservation of momentum principle. The initial speed of the rocket is 1192.0 m/s, and the first stage, which is twice as massive as the second stage, is pushed backward at 32.4 m/s relative to the second stage. After correcting an initial misunderstanding about relative speeds, it is clarified that the first stage continues to move upward but at a reduced speed. The final calculation for the second stage's speed results in approximately 1181 m/s after accounting for the momentum conservation. The conversation highlights the importance of understanding relative motion in such problems.
MightyMan11
A two-stage rocket is traveling at 1192.0 m/s with respect to the Earth when the first stage runs out of fuel. Explosive bolts release the first stage and push it backward with a speed of 32.4 m/s relative to the second stage. The first stage is 2.00 times as massive as the second stage. What is the speed of the second stage after the separation?
Conversation of momentum.
I first set the second stage's mass as "m". The mass of the first stage then would be "2m" and the total rocket would have a mass of "3m".
Using the conservation of momentum I made an equation:
momentum of first stage+momentum of second stage= momentum of the rocket
(-32.4)*(2m) + v(m) = 1192(3m)
the m's cancel out and I solved for v:
3,640.8 m/s
however this does not match the answer in my textbook... :/
Thanks in advanced.
Note the word "relative". It is highly significant!
Wow,
I didn't catch that...
Does that mean then the first stage of the rocket is still moving up, just at a slower speed than the second stage? (1192-32.4=speed of first stage)?
And since the first stage is "slowing down", if momentum is conserved the second stage should "speed up"?
It means that, if v1 is the fist stage's velocity, v2 the secondstage,
then we have the equation:
v_{1}-v_{2}=-34m/s\to{v}_{1}=v_{2}-34m/s
Thus, energy conservation becomes:
(2m)(v_{2}-34)+mv_{2}=(3m)1192
Solving for v2, we get:
3mv_{2}=m(3*1192+2*34),
which you can manage on your own.
And yes, the other stage will still be moving upwards, at approximately 1181m/s
Ah.
Thank you very much for your help.
