Physics undergrad -> ph.D Mech E
Graduating with a B.Sc. in physics and transitioning to a Ph.D. in mechanical engineering, particularly in materials research, is a common path. Many believe that a physics background can provide a strong foundation for understanding complex engineering concepts. Challenges may include additional coursework and adapting to different methodologies, but the skills gained in physics can be advantageous. Research areas, such as material fatigue and microscopic crack growth, highlight the interdisciplinary nature of the field. Overall, the transition is manageable and can lead to valuable insights in mechanical engineering.
awri
So I will graduate in a few weeks with a B.Sc. in physics and I will begin my phD studies in the fall in mechanical engineering. Paticularly, my research will be in materials. Can anyone shed some light on this transition? I understand that there will be loads of work and some makeup classes, etc. What I am really interested in, is has anyone done this before? What was most difficult? How did you cope with not being from an Mech E undergrad dept?
I Asked this in the academic forum awhile ago and got no responce so I am asking in here this time.
I don't think it will be half as bad as you think. Because you did physics, you might be better off.
Depending on what aspect of materials you are focusing in, your probably won't even be tell that you're getting a degree in ME and not physics.
I believe my research is in the area of material fatigue. Something along the lines of how microscopic cracks grow and expand and cause breakdown...
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
