Piping material specification(PMS)
  • Thread starter Thread starter shahinmp
    Material Piping
Piping material specifications (PMS) are crucial for selecting appropriate materials for piping components based on the type of fluid being transported. Common materials like A106 Gr B for vapor pipes and A105 for flanges are standard, but the choice may vary with different fluids such as gas, oil, or styrene monomer. Engineers should reference ASME, BS, and ASTM standards to guide material selection. Understanding the specific requirements of the fluid and the operating conditions is essential for ensuring safety and performance. Engaging with industry standards and guidelines will provide clarity in material selection for various applications.
shahinmp
Dear Engineers
I am very curious to know about Piping material specifications (PMs) .
How can I select the appropriate material for components which is used in piping? For example we use A106 Gr B for vapour pipes or A105 for flanges and A105/A234 for fittings less/bigger than 2". Now I want to know if the fluid changed to gas or oil or for example styrene monomer how I should choose these materials.
what is the main refrence for choosing these materials? Are ASME or Bs or ASTM standards used for this?
Thanks in advance!
I am coming everyday to find some answers or helps to my question but no answers available! what's the problem?
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
