Pivoting Antenna Deployment Hinge
  • Thread starter Thread starter dbelgiovane
    Antenna Hinge
An electrical engineering graduate student is developing a pivoting hinge deployment system for a conical antenna mounted under a twin-engine airplane fuselage, required for remote sensing during takeoff and landing. The antenna is 36 inches tall with a 10-inch base diameter, and the design aims for electronic control, ideally fitting within a 12x12 inch space. Initial ideas include using an air cylinder, but concerns about temperature constraints and size have arisen. A tilt table design has been proposed, featuring a servo motor for raising and lowering the antenna, though there are worries about potential icing and joint mobility. The student seeks feedback on the design's feasibility and potential flaws.
dbelgiovane
Hello,
I am an electrical engineering graduate student building an antenna which will be mounted under the fuselage of twin engine airplane which will be taking remote sensing measurements. Besides the antenna design I have also been tasked with developing the method of deployment as well. deployment is required during takeoff and landing because it is 36 inches tall. The antenna is conical in shape with a base diameter of 10 inches.
I have a few ideas about the design, but since I am not a mechanical engineer, I could really use some help.
I seems like some type of pivoting hinge deployment is the simplest. and I have a rough figure of the basic sketch, but basically the pivoting hinge should be able to go from 0 - 90 degrees. Ideally, it should be electronically controlled. I the idea I had uses an air cylinder, but these may be issues due to temperature constraints. Additionally, this design may take up too large of an area. The use of a scissor lift type hinge might be a useful method but, I have not come up with a good implementation yet.
So, a most ideal design would be able to deal with subzero temperatures, be able to be mounted flush with the fuselage, be able to fit inside roughly a 12in by 12in space.
Thank you in advance!
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
Hey Guys, with regard to this concept, I came across tilt table that goes from 0-90 degrees:
http://www.schapmachine.com/ProductView/215/Automotive/Tilt_Table/
The overall design seems like enough torque can easily be generated it is low profile enough. I plan to install a servo motor which will raise an lower the platform.
My concerns are if I am to move forward with this concept, am I missing any design flaws. Will it be susceptible to icing and will all the joints move freely?
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
