Arranging Deputies on a Bench with Restrictions
  • Thread starter quasar987
  • Tags
    Row
In summary, there are \binom{8}{2}7!2!^2 possible ways to place ten deputies on a bench, given that the Russian and American deputies do not want to be placed side by side and the English and French deputies want to be side by side. This can be calculated by placing all deputies except for the Russian, then placing the Russian and taking into account the possible permutations of the deputies. Another approach is to count all permutations and then subtract the number of permutations where the Russian and American are side by side, which can also be expressed as \binom{8}{2}7!2!.
quasar987
32
Ten deputies must be aligned on a bench. How many ways of doing that is there, provided that the russian deputy and the american deputy do not want to be placed side to side, and that the english and french ones want to be side to side.
Since the english and the french deputies want to be side to side, let's consider them as 1 deputy for the time being (more preceisely, for the portion of the solution that treats the deputies as indistinguishable from one another).
Let's denote x1 the number of deputy placed on the russian's left, x_2 the number of deputy placed in btw them and x3 the number of deputy to the american's right. x1 and x3 can be zero but x2 must be at least 1. Of course x1+x2+x3 must be 7. The number of non-negative integer solutions to x1+x2+x3=7 under the constraint x2[itex]\geq[/itex]1, is the same as the number of positive integer solution to (x1-1)+x2+(x3-1)=7 <==> x1+x2+x3=9 Based on the fact that the number of positive integer solutions to [itex]x_1+...x_r=n[/itex] is [itex]\binom{n-1}{r-1}[/itex], the number of ways to place the deputies (indistinguisably) around the american and the russian is thus [itex]\binom{9-1}{3-1}=\binom{8}{2}[/itex].
Taking into account all the possible permutation of the 7 deputy amongs them, we get [itex]\binom{8}{2}7![/itex]. Taking into account the possible permutation of the russian and the american, we throw a 2! into the mix. And finally, in order to take under consideration the possible permutations of the ensligh and french deputy we throw one last 2! into the mix and the glorious final answer is
[tex]\binom{8}{2}7!2!^2[/tex] :approve: At first I had doubt about my solution, but it looks pretty solid now. Looks good?
That looks fine. Another appraoch would be to count all permutations not caring where the russian and american are, then subtract the number where they are side by side.
Looks good, though that "number of positive solutions" formula threw me (the formula which I find easier to remember is for the number of non-negative solutions). There is a simpler way to do it:
1. Place everybody but the Russian. 8! * 2
2. Place the Russian. 7 * 8! * 2
Wow neat!
shmoe, I tought about using that method at first, but could not see what an expression for the number where they are side by side would be.
I'm sure you can... you were able to deal with the English and French deputies getting cozy, the Russian and American are no different.
1. How many different ways can 10 deputies be placed on a row?
There are 3,628,800 possible ways to place 10 deputies on a row. This can be calculated using the formula n! (n factorial) where n represents the number of deputies (10! = 10 x 9 x 8 x 7 x 6 x 5 x 4 x 3 x 2 x 1 = 3,628,800).
2. Is there a specific placement order for the 10 deputies?
Yes, there is a specific placement order for the 10 deputies. They can be placed in any order, but each deputy must be placed in a specific spot on the row. For example, if the deputies are numbered 1-10, deputy 1 must be in the first spot, deputy 2 in the second spot, and so on.
3. What is the probability of a specific deputy being placed in a specific spot?
The probability of a specific deputy being placed in a specific spot depends on the number of deputies and the total number of spots. In this case, with 10 deputies and 10 spots, the probability would be 1 in 10 or 10%. However, if the number of deputies or spots changes, the probability will also change.
4. Can two deputies be placed in the same spot on the row?
No, two deputies cannot be placed in the same spot on the row. Each deputy must have their own designated spot in order to be considered placed on the row.
5. How does the placement of the deputies affect the overall outcome or result?
The placement of the deputies may affect the overall outcome or result in different scenarios. For example, if the deputies are participating in a race, their placement on the row may determine their starting position and potentially impact their chances of winning. In other situations, the placement may not have any significant impact on the outcome.
  • Linear and Abstract Algebra
9K
