Plane Equations Homework: Parallel, Coincident, Distance
  • Thread starter Thread starter fazal
    Plane
4 replies · 3K views
fazal
a)Determine whether the following two planes 3x-y+z=2 and 2x+2y-4z=5 are parallel, orthogonal,coincident (same) or none.
b)Find the equation of the plane that contains the point (2,3,-1) and parallel to the plane 5x-3y+2z=10
c)Find the distance from the point (3,5,-8) to the plane 6x-3y+2z=28
Hi fazal! :wink:
Show us what you've tried, and where you're stuck, and then we'll know how to help. :smile:
for A)
take the dot product of the two normal vectors. if its zero then they're perpendicular ?
take the cross product of the two normal vectors. if its zero then they're parallel ?
For them to be the same they'd have to be linear multiples of each other? how?
B)Parallel to the plane 5x-3y+2z=10 means a vector normal to the plane is (5, -3, 2). So the equation has the form 5x - 3y + 2z = d. To get d, substitute the point (2,3,-1).
therefore is the equation 5x-3y+2z=-1 after sub the above??
plse check for me...
c)For c, use the formula:
so the answer is:- 41/7
plse assist to check
fazal said:
for A)
What are the normal vectors for these planes? Are they parallel? Are they perpendicular?
For two vectors to be parallel, not "the same", one has to be a multiple of the other: <3, 2, 1> and <6, 4, 2> are parallel because <6, 4, 2>= 2<3, 2, 1>.
Why would you need someone else to check for you? Is 5(2)- 3(3)+ 2(-1)= 1?
Is that supposed to be negative? A distance is never negative.
