Planet and Car rotational movement
A newly discovered planet with a mean radius of 1230 km has a vehicle moving at 130 km/h in the same direction as the planet's rotation. The vehicle's angular velocity is 6.18 times that of the planet, leading to the calculation of the planet's rotation period, approximately 307.944 hours. When the vehicle reverses direction, it must achieve an angular velocity equal and opposite to the planet's, which does not result in a speedometer reading of zero. The confusion arises from misunderstanding the relationship between angular velocities when reversing direction. The correct approach requires setting the vehicle's angular velocity to the negative of the planet's, not equal to it.
qqchan
A newly discovered planet has a mean radius of 1230 km. A vehicle on the planet's surface is moving in the same direction as the planet's rotation, and its speedometer reads 130 km/h. If the angular velocity of the vehicle about the planet's center is 6.18 times as large as the angular velocity of the planet, what is the period of the planet's rotation?
If the vehicle reverses direction, how fast must it travel (as measured by the speedometer) to have an angular velocity that is equal and opposite to the planet's?
v=rω
T = 2∏/ω
Since the value from the speedometer is relative to the ground, the following equation is developed:
v = 6.18rωplanet
v = 130 + rωplanet
v - rωplanet = 130
6.18rωplanet - rωplanet = 130
5.18rωplanet= 130
ωplanet = 130/(5.18 *1230)
T = 2∏/ωplanet
≈307.944
However when the vehicle reverses its direction to have an angular velocity similar to that of the planet, wouldn't the result of the speedometer be zero? However, the teacher said it isn't zero.
planet - rωplanet = Vspeedometer
I would like to know what is wrong in my thought process when attempting to solve this equation
v=rω
T = 2∏/ω
v = 6.18rωplanet
v = 130 + rωplanet
v - rωplanet = 130
5.18rωplanet= 130
T = 2∏/ωplanet
≈307.944
Well, yes. If you want the car to have the same angular velocity as the planet, ##r \omega_v=r \omega_{planet}##, then the velocity is 0. But you don't want that, you want ##r \omega_v= -r \omega_{planet}##.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
