Can Plastic Be Made Without Oil?
In summary, plastic can be made from sources other than oil, such as carbon extracted from CO2 or rock, oxygen from atmosphere or sea water, hydrogen from sea water, and nitrogen from atmosphere or other sources. However, the process is currently economically inefficient and technically difficult due to the stability of these compounds and the need for specific functionalities for polymerization. Even with the potential of fusion power providing limitless clean energy, it may not be feasible to completely replace oil as a starting material for the chemical industry, especially in air transportation where high capacity energy storage methods are still lacking.
Stephanus
1,316
104
Can plastic be made NOT FROM oil?
And not from remains of living organic matter.
I mean, we extract carbon from atmosphere CO2 or from the rock...
Oxygen from atmosphere or sea water...
Hydrogen from sea water...
Nitrogen from atmosphere or other sources...
Combine them together and voila, we get plastic.
Is the process economically inefficient?
Is the process technically difficult?
Is the process scientifically impossible?
Thanks.
Chemistry news on Phys.org
Plastics are polymers of hydrocarbons. There are many things to consider about why it is very difficult (sometimes currently impossible) and very economically inefficient to make plastics from the starting materials you mentioned.
Carbon, in the form of CO2, is incredibly stable. It takes a significant amount of energy to functionalize the CO double bonds since they are so stable.
Polymers, of any kind, need a way to be polymerized. This means they need some sort of functionality on them that can be reacted with. Polyvinylchloride (PVC) for instance is made from vinyl chloride which has the electron poor double bonds which link together in the polymerization reaction.
Now couple these two things together. It is not economically feasible to make plastics in this way.
Likes Stephanus
Thanks for your answer.
It's just an idea. If fusion power is in operational and if we can gain limitless clean energy...
We'll be free completely from oil dependency
Think this way: plants are capable of producing polymers using the compounds you have mentioned. Cellulose, caoutchouc, DNA, proteins - these are all polymers. While they don't necessarily fit the notion of 'plastic' in a common understanding of the word, they share many general chemical properties. So from the purely chemical point of view answer to your question is "yes".
Whether it is economically viable is a completely different question.
That's why Sun have helped us making plastic hundreds of millions of years ago?
It's just that someone in the other thread says that we can't be independent from oil, even though we are able to build fusion power plants. But that's out off scope :smile:
About the fusion power, it's not yet feasible.
Oil is a great start-up for the chemical industry. And while most of it is used for power generation only about 3% goes to chemical plants, and a fraction of that to plastics. That could in theory and a very expensive practice be replaced by other hydrocarbon sources, for example vegetable oil (which requires a lot of chemical processing).
But the main issue IMO is the air transportation, were fueling airplanes takes around 6% (not exact just google) of the world supply.
On land you could build electric solutions, yet in air we have no other high capacity energy storage method to date to rival with hydrocarbons. So we will survive life without oil, but we will not fly that much.
1. How is plastic currently made?
Plastic is currently made from petroleum, a type of fossil fuel that is extracted from the ground. The petroleum is processed into different chemical compounds, which are then used to create various types of plastic.
2. Why is using oil to make plastic a problem?
Using oil to make plastic is problematic for several reasons. First, oil is a non-renewable resource, meaning that it will eventually run out. Second, extracting and processing oil can have negative environmental impacts such as air and water pollution. Finally, burning plastic made from oil releases carbon emissions, contributing to climate change.
3. Can plastic be made without oil?
Yes, it is possible to make plastic without using oil. There are several alternative sources of materials that can be used to create plastic, such as plant-based materials like corn starch or cellulose. These materials are renewable and have a smaller environmental impact compared to oil-based plastic.
4. Is plastic made without oil as durable as traditional plastic?
Yes, plastic made without oil can be just as durable as traditional plastic. In fact, some plant-based plastics have been found to be even stronger and more flexible than their oil-based counterparts. However, the exact properties of the plastic will depend on the specific materials and processes used to create it.
5. What are the challenges of making plastic without oil?
There are several challenges to making plastic without oil. One of the main challenges is finding alternative materials that are both cost-effective and readily available. Additionally, the processes for creating plastic from these materials may require additional research and development. There may also be challenges in terms of scaling up production to meet the demand for plastic without oil.
  • Nuclear Engineering
  • Earth Sciences
