Instrumentation Course: PLC Programming for Beginners
PLC programming does not require prior knowledge of C, as each PLC manufacturer has its own programming language and methods. Familiarity with concepts like Karnaugh maps and PID control is beneficial, but the implementation varies by PLC. Learning Relay Ladder Logic (RLL) is essential, as it emulates traditional wiring practices, although this can lead to poorly written software if not approached correctly. Understanding the specific processes and quirks of the I/O is crucial for effective programming. Practical experience in the field is important for educators to provide relevant insights into real-world applications.
Gursimranjeet
Hi everyone,
I have opted for an instrumentation course and I am worried about the programming part as i don't have much knowledge about programming. Is it necessary to learn C before learning PLC programming or i could start from plc programming? If I could start from plc then which book i should follow as a beginner?
Thanks in Advance
C is a standard programming language, but there is no standard "PLC programming language". Every PLC manufacturer has his own PLC programming language and programming methods. Included in some PLC program is for example:
- Logical control which could be programmed by use of ladder network or sequential network.
- Dynamic control of motors ( e.g. PID controllers ).
- Human/machine interface ( HMI ).
- Local area network ( LAN ).
Generally it's a good idea to be familiar with Karnaugh maps ( reduction of logical expressions ) and PID control, but as said above, the method as how to implement the requirements, strongly depends on the PLC used.
Likes Gursimranjeet and JakeBrodskyPE
More detailed information:
https://www.udemy.com/plc-programming-from-scratch/
Likes Gursimranjeet
Relay Ladder Logic programing languages came into being because it tried to emulate what electricians were wiring up every day. In essence, they were attempting to take electricians and make them into programmers. That sort of thinking didn't always work well. They often wrote awful RLL software. However, the opposing point of view, that software programmers could write reasonable programs around an industrial process is also deeply flawed for the opposite reason.
Ultimately, to learn RLL well, you need to become intimately familiar with a process, and all the quirks of the I/O. For example, if a valve actuator is moved from, say 10% to 60% open, it may overshoot and need to work backwards a bit. This could confuse a poorly written program that just assumes that the actuator will always hit the target perfectly.
Your professor won't know a damned thing about these sorts of problems UNLESS they have at least a couple years of hard-hat field experience. If they have that, then pay attention! If they don't, or they consult here and there, you might as well focus on just passing the tests.
Likes Hesch and Gursimranjeet
Thanks a lot Hesch!
As i have done Degree in Electronics and have good knowledge about karnaugh maps and I will be studing about PID. Thanks for the link will look forward to join that.
Thanks
Thanks Sir! I appreciate your valuable advise.
33K
