How Do You Calculate Frictional Force on an Inclined Plane?
In summary, the homework statement states that a 5.60 kg block is set into motion up an inclined plane with an initial speed of v0 = 8.10 m/s. The block comes to rest after traveling 3.00 m along the plane, which is inclined at an angle of 30.0° to the horizontal. The first question was to find the change in kinetic energy, which ZI found to be -183.708. The second question was to find the change in potential energy, which I found to be 82.404. The third question is determine the frictional force exerted on the block(assumed to be constant). I can't seem to figure out the third question. After finding
junior20
I am struggling a little bit on this problem. Any help is appreciated.
A 5.60 kg block is set into motion up an inclined plane with an initial speed of v0 = 8.10 m/s. The block comes to rest after traveling 3.00 m along the plane, which is inclined at an angle of 30.0° to the horizontal.
After finding the frictional force, it asks for the coefficient of kinetic friction, which I'm sure i can find by dividing the frictional force by the normal force.
Ff = μFn
where Ff is the frictional force, μ is the coeifficient of kinetic friction, and Fn is the normal force.
F=ma
F is the force on the mass, m is the mass, a is the acceleration
v2 = vo2 + 2a(Δx)
v is final velocity, vo is initial velocity, a is acceleration, Δx is the displacement
Acceleration I found to be -10.935
Normal force = 47.57592
I have found acceleration to be -10.935. So I found the total force to be -61.236. I have tried to solve for the frictional force by setting the total force equal to the frictional force + gravitational force and solved for frictional. I have also made other attempts but they were very random and I don't recall what made me come up with them. I have submitted 5 incorrect answeres so far.
I tried to upload a picture of the slope and block, I'm not sure if it worked.
Thanks in advance for any help.
You need resolve your forces into components. It may be wise to choose the direction of the inclined plane to be the x-axis and thus the direction that is perpendicular to it to be the y-axis.
Now you can say that [itex]\sum F_y=ma_Y[/itex] and[itex]\sum F_x=ma_x[/itex]
Thank you for your prompt response. I'm am having a hard time understanding your help.
I should set the direction of the incline to the x-axis. So wouldn't that make the [itex]\sum F_y=ma_Y[/itex] equal to zero? Then the [itex]\sum F_x=ma_X[/itex] would be the same becuase my acceleration is th same?
I don't think I am quite understanding what your telling me.
If the direction of the plane is the x direction, then clearly the acceleration cannot be zero since the block is initially moving and then comes to rest. So why should the sum of the forces in that direction be zero?
Looking at a Free body diagram (which I presume you have already drawn:smile: ) you should see that there are are two forces acting on the block in the direction of the plane.
Can you identify those two forces?
Sorry, what I meant by the x acceleration being the same was that I meant it would be the same as I have already calculated to be -10.935.
The two forces acting parallel to the direction are the gravitational force of 9.81*5.6*Tan(30) and the Frictional force. I think.
Tan? I do not think it shall be tan 30? Perhaps sin 30?
The force parallel to the x axis( the incline) should be mgsin(30). When splitting vectors into components you use sin and cos. Also since you know the initial energy and the final energy you can make a comparison. Was energy conserved? Obviously not as friction is a non conservative force. how much energy was lost to friction over the 3.0m or how much work did the frictional force due? How is the coefficient related to your knowns?
Related to How Do You Calculate Frictional Force on an Inclined Plane?
What is Frictional Force?
Frictional force is the resistance force that occurs when two surfaces come in contact and move against each other. It is caused by the irregularities and imperfections on the surfaces and can impede the motion of an object.
How is Frictional Force calculated?
The magnitude of frictional force can be calculated using the formula F = μN, where F is the frictional force, μ is the coefficient of friction, and N is the normal force between the two surfaces. The coefficient of friction depends on the nature of the surfaces in contact and can be determined experimentally.
What factors affect Frictional Force?
The magnitude of frictional force can be affected by several factors such as the nature of the surfaces in contact, the amount of force applied, the surface area of contact, and the speed of movement. The type of motion, whether it is sliding, rolling, or fluid friction, can also influence the frictional force.
Why is Frictional Force important?
Frictional force plays a crucial role in everyday life. It helps us to walk, hold objects, and stop moving objects. It also enables vehicles to move on the roads, and machines to operate effectively. Frictional force is also essential in controlling and preventing accidents, as it allows us to grip and control objects and surfaces.
How can Frictional Force be reduced?
Frictional force can be reduced by using lubricants, such as oil or grease, between two surfaces. Smoother surfaces can also help to decrease frictional force. In some cases, reducing the amount of force applied or changing the type of motion can also reduce the frictional force. However, it is important to note that frictional force is necessary for many daily activities and reducing it entirely can cause problems.
