Understanding Ohm's Law and Charge Units in Electrodynamics
  • Thread starter Thread starter yungman
    Law Ohm's law
The discussion focuses on understanding Ohm's Law and charge units in electrodynamics, specifically referencing equations from Griffiths' "Introduction to Electrodynamics." It clarifies that the unit charge is indeed one coulomb, which is essential for deriving the relationship between current density (J), conductivity (σ), and electric fields (E) in the context of moving charges. The transition from the equation J = σ(E + v x B) to the simplified form f = E for a unit charge is confirmed, emphasizing that if the velocity of the charge is negligible, the magnetic force can be disregarded. Participants express clarity on these concepts, reinforcing the foundational principles of electrodynamics. Overall, the conversation highlights the simplicity of these relationships when understood correctly.
yungman
This is referring to Chapter 7.1, page 285 of "Introduction of Electrodynamics" 3rd edition by David Griffiths.
\vec J = \sigma \vec f \;\; \;\;\;\;\;\;\;( \frac{C}{m^2\cdot sec}) (1)
Where f is force per unit charge. Is the unit charge one coulomb?.
Also
\vec J = \sigma(\vec E +\vec v X \vec B)\;\;\;\;\;\;\;\;\;\;\; (\frac{C}{m^2\cdot sec} ) (2)
My understanding is force:
\vec F = q(\vec E +\vec v X \vec B) \;\;\;\;\;\;\;\;\;\; \hbox {( N) }
For unit charge of one coulomb,
\vec f = (\vec E +\vec v X \vec B) (3)
How do I go from (2) to (3)
Thanks
yup, the unit charge is a coulomb
Equation 1 shows how you get from 2 to 3
Thanks for the reply.
So if \vec f is unit force which is the force of a coulomb charge.
\vec F = Q\vec E = 1\;X \;\vec E = \vec E \hbox { for Q = one coulomb }?
Therefore
\vec J \;=\; \sigma \vec E = \sigma \vec f
if the velocity of the unit charge is slow and
Q (\vec v X \vec B) is ignored.
Am I getting this right? Just that simple? What was I thinking!:cry::eek:
Thanks
Alan
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
